86 subaru gl key won't turn ignition anymore
  xbeerd said:
turn the steering wheel a little bit back and forth?
This is Good Idea to Try that, Specially if the Steerin' Lock got Stall.
Also I Kindly Suggest to Spray some Lubricant inside that ignition Switch, Such as WD-40 or PB Blaster; it could help to Free a Stuck Mechanism.
Good Luck,
Kind Regards.
I once had a locksmith chastise me for this (even though I hadn't done it). She said you should never do that, but instead spray silicon lube on the key itself and work the key in the ignition (several times if needed). Apparently excessive doses of petroleum based products eventually gum-up and can cause other problems as well.
I have always done it the way she described and have had zero problems.
