chad barker Posted September 14, 2011 Share Posted September 14, 2011 can somebody please look on their ea81 engine that has air conditioning and post the number of the belt reguardless of the brand pleeeeaaassseeee so i can have somewhere to start as nobody around can make one available to order and the car didnt come with one. so much thanks and does anyone have a plastic clutch alignment tool to trade, rent, ect? they say there not made anymore outside of an expensive clutch kit... Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 14, 2011 Share Posted September 14, 2011 Just wrap some twine around the pulley's and measure it. It will likely be an "A" cross-section and then you just need the OD of the belt in inches. GD Quote Link to comment Share on other sites More sharing options...
Idasho Posted September 14, 2011 Share Posted September 14, 2011 GATES Part # 5740 It is a 1/2 x 54" V-belt. Rockauto has 4 brands of the same belt. Goodyear, ACdelco, Gates, and Dayco Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 14, 2011 Share Posted September 14, 2011 You can't give him a belt number - the year and type of AC makes a differerence. He needs to go to the dealer or measure it. GD Quote Link to comment Share on other sites More sharing options...
Idasho Posted September 14, 2011 Share Posted September 14, 2011 He asked for a ea81 AC belt number. So I gave him a number. From his first post the car came with AC, but it simply didnt have a belt. As for a clutch alignment tool, you really dont need one. Eyeball it, but do not torque the pressure plate down all the way, then mate the motor to the trans, THEN tighten the pressure plate down through the starter hole. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 14, 2011 Share Posted September 14, 2011 He asked for a ea81 AC belt number. So I gave him a number. From his first post the car came with AC, but it simply didnt have a belt. Different years got different brands of compressors and mounting brackets - some were factoy installed while others were dealer installed - all of which can mean different belts. Your number is meaningless without knowing what type of AC system he has and what year it is..... Wraping a bit of twine around the pulley's will easily tell you what belt you need. Then you can just go on McMaster's web catalog and reference the "A" spec number. GD Quote Link to comment Share on other sites More sharing options...
chad barker Posted September 15, 2011 Author Share Posted September 15, 2011 thank you both very very much for all of the opinions and info... Quote Link to comment Share on other sites More sharing options...
