1-3-2-4 Posted September 14, 2011 Share Posted September 14, 2011 To get the keyless entry for my 97 OBW all I need is 88035AC210 & 88036XA010? I'm going to guess the wires are tucked away taped maybe? under the dash? Link to comment Share on other sites More sharing options...
lmdew Posted September 14, 2011 Share Posted September 14, 2011 I most likely have the unit for you $45 shipped. No fobs. Check for the connectors, if they are not there, the harness is also needed. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 14, 2011 Author Share Posted September 14, 2011 I will check today after work Link to comment Share on other sites More sharing options...
eulogious Posted September 14, 2011 Share Posted September 14, 2011 Aftermarket? Cheaper, and there are install instructions I picked up my keyless entry and remote start for $20 used off of ebay. Almost 2 years later it's still working like a champ! Only took about an hour and 3 relays to install the keyless entry part of the system. You do need some 12v experience though, just a thought... Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 14, 2011 Author Share Posted September 14, 2011 bI dont think I see the harness not sure if it is behind the panel Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 15, 2011 Author Share Posted September 15, 2011 The build date on my car is 1/97 Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 17, 2011 Author Share Posted September 17, 2011 Hmm I was looking at the service manual to see if it talked a bit over the keyless system.. might be helpful since it tells which color the connectors are. It appears that all the connections I will be looking for would be black instead of translucent. Link to comment Share on other sites More sharing options...
lmdew Posted September 17, 2011 Share Posted September 17, 2011 yes, the connectors are a clearish white. You most likely need the harness as well. Shoot me an email and i'll send you a picture of the unit and harness. Lmdew@hotmail.com Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 17, 2011 Author Share Posted September 17, 2011 email sent Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 19, 2011 Author Share Posted September 19, 2011 Still checking.. but what I do know is it did have some type of aftermarket alarm.. funny thing is they mounted the alarm speaker where the stock one would go in like the same way in all.. But since I don't know much about the aftermarket systems don't they just plug into the factory harness? I keep getting busy with work so I really haven't had much time to look again but I can tell you is whatever they used tied into some wire harness and something else near the fuse panel along with a push button switch. Link to comment Share on other sites More sharing options...
jarl Posted September 21, 2011 Share Posted September 21, 2011 From the sets I have seen, aftermarket alarms are not usually made to interface nicely with the car wiring. Maybe the PO had to replace the original alarm? Link to comment Share on other sites More sharing options...
rverdoold Posted September 21, 2011 Share Posted September 21, 2011 I was thinking of installing key-less entry system. However does the driver door has an actuator with standard all-door locking system? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 23, 2011 Author Share Posted September 23, 2011 You mean does the key part link to the door unlock thing that you push to lock (can't think of the right term) Link to comment Share on other sites More sharing options...
rverdoold Posted September 23, 2011 Share Posted September 23, 2011 1-3-2-4 said: You mean does the key part link to the door unlock thing that you push to lock (can't think of the right term) You mean the door lock switch on the inside of the door. When I push it feels like I am turning the cylinder. Although when I push that one all other doors lock as well. So it is actuating. Really do not want to open the door and see there is one. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 23, 2011 Author Share Posted September 23, 2011 rverdoold said: You mean the door lock switch on the inside of the door. When I push it feels like I am turning the cylinder.Although when I push that one all other doors lock as well. So it is actuating. Really do not want to open the door and see there is one. Oh on my car pushing that does not lock/unlock all other doors I have to press the button for that same when unlocking the door with the key. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 30, 2011 Author Share Posted September 30, 2011 SOA did finally get back to me and they did tell me the 97 outback did have an option for keyless entry.. I just don't understand why I have no disconnected plugs under my dash the damn plugs gotta be big enough to see?? Link to comment Share on other sites More sharing options...
Regardie Posted October 11, 2011 Share Posted October 11, 2011 My 97 Legacy L has the remote keyless entry system installed. It was a dealer add-on, and there are a bunch of wires tapped into various connectors under the dash. I would imagine that you would need the whole kit, security module, harness and two keyfobs, plus the service install instructions. The car as shipped had some form of remote lock unlock system that the security system superseded. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 11, 2011 Author Share Posted October 11, 2011 I emailed Joe at cars 101 and he said this about the 97 " Hi, asked a mechanic and late 98s had a quick connect, otherwise no. And parts are no longer available. Go aftermarket? Joe" I had people swear that I was not looking hard enough at other sites... Ok so I can't use a Subaru one since it has no plugs.. And I can't tell what is going to what.. The thing with aftermarket systems is I don't need/want the alarm part. Link to comment Share on other sites More sharing options...
lmdew Posted October 17, 2012 Share Posted October 17, 2012 When I pull them out at the yard, I'll pull the car side of the harness connectors as well so you can see where they plug in on the new car. Works well. Wish I had one now, as the car I'm working on had a system but someone pulled it and now the Drivers door does not lock and unlock with the door lock/unlock button. Power down to the plug in the forward kick panel but no ground. The ground must have been cut when the security system was put in. I have to hunt one down. Link to comment Share on other sites More sharing options...
