landozion Posted September 16, 2011 Share Posted September 16, 2011 Posting this to help anyone who may have the same problem. 97 OBS, about one out of 10 starts it would act like it flooded and take extended cranking to catch. No codes. Started getting worse till it was every other start. Still no codes. Replaced the Engine Coolant Temp Sensor, problem fixed, been two weeks now and two tanks of gas, mpg is up 3mpg. Link to comment Share on other sites More sharing options...
lmdew Posted September 16, 2011 Share Posted September 16, 2011 What took you to the coolant temp sensor? Nice fix and thanks for the info. Link to comment Share on other sites More sharing options...
lewisd Posted September 16, 2011 Share Posted September 16, 2011 LOL.... I thought I read your gas mileage IS 3 mpg... LOL congrats on the fix! Link to comment Share on other sites More sharing options...
landozion Posted September 16, 2011 Author Share Posted September 16, 2011 Spent several hours on the forums here searching flooding/hard start and no code/no start conditions, and one of the possibilities was the ects. Symptoms fit (engine doesnt know how warm it is and compensates with extra gas) and i had a sensor from my parts car. Currently getting 26mpg around town. Link to comment Share on other sites More sharing options...
davebugs Posted September 16, 2011 Share Posted September 16, 2011 Actually it's a common problem/solution on other cars. I used to buy a lot of Saturns cheap due to this. Install eht enew redesigned CTS and often drive the car home. ALso there are 2 CTS's on a Subaru I believe. Because one time I left the one with a spade terminal around #3 intake off when doing a HG job. Link to comment Share on other sites More sharing options...
987687 Posted September 17, 2011 Share Posted September 17, 2011 The two pin one goes to the computer. And the one pin one goes to the gauge. That's why if the one to the computer fails you still get a good reading on the gauge. An OBD2 reader could easily show that the computer isn't getting the correct reading. I found out about that one spade one too (left it out). Found it out pretty quick when I started adding coolant... Link to comment Share on other sites More sharing options...
