danzick Posted September 16, 2011 Share Posted September 16, 2011 (edited) So these have probably 1000 miles on them. The car is kinda slugish on the insterstate and has a midrange sort of lag Edited September 16, 2011 by danzick Link to comment Share on other sites More sharing options...
81EA81 Posted September 16, 2011 Share Posted September 16, 2011 Im sure its just running too lean. too much air vs fuel Link to comment Share on other sites More sharing options...
danzick Posted September 16, 2011 Author Share Posted September 16, 2011 Well ya I know that. Im basically asking how I get it to a more brown color. Its a 88 spfi. Not like I can just go change jetting. Fuel filter is good. Just put a new top throttle body on it with an injector cause mine was shot Link to comment Share on other sites More sharing options...
Dirk Posted September 16, 2011 Share Posted September 16, 2011 Wouldn't hurt to check timing. Also vacuum hoses and the like for air leaks. Are all the plugs the same colour? Not familiar with these engines but would a bad O2 sensor do this? Link to comment Share on other sites More sharing options...
MilesFox Posted September 16, 2011 Share Posted September 16, 2011 Suspect MAF and/or ects(coolant sensor) Link to comment Share on other sites More sharing options...
edrach Posted September 17, 2011 Share Posted September 17, 2011 Which plug and heat range are you using? Link to comment Share on other sites More sharing options...
danzick Posted September 17, 2011 Author Share Posted September 17, 2011 I dunno what plugs. Just whatever napa gave me in the ngk form. And its got all new vacuum lines and I cleaned the maf sensor Link to comment Share on other sites More sharing options...
Mykeys Toy Posted September 17, 2011 Share Posted September 17, 2011 The o2 could do it but more than likely it is maf related. Link to comment Share on other sites More sharing options...
danzick Posted September 18, 2011 Author Share Posted September 18, 2011 the 02 sensor looks pretty new, and the MAF sensor looked great even before i cleaned it, and i used actual maf sensor cleaner. and i just bought a new Coolant temp sensor. Link to comment Share on other sites More sharing options...
ruparts Posted September 18, 2011 Share Posted September 18, 2011 danzick said: the 02 sensor looks pretty new, and the MAF sensor looked great even before i cleaned it, and i used actual maf sensor cleaner. and i just bought a new Coolant temp sensor. hi, looks don't count with parts, actual readings do , the temp sensor wires & the connections to it are usually the problem rather than the actual sensor. take readings on all the parts to see if they are actually doing what they should , check for stored codes in the ecm. Link to comment Share on other sites More sharing options...
danzick Posted September 19, 2011 Author Share Posted September 19, 2011 i have a crank angle sensor/circut code in the ecu Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted September 21, 2011 Share Posted September 21, 2011 need new rotor or pulg wire? Link to comment Share on other sites More sharing options...
danzick Posted September 22, 2011 Author Share Posted September 22, 2011 All the plug wires look pretty new far as I can see Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted September 26, 2011 Share Posted September 26, 2011 try check fuel injection into carb if there's' bad or worn out? or check your AIR FLOW SENSORS or maybe Piston Ring worn out? dose your muffler black smog problem? how many miles your suba wagon? danzick said: All the plug wires look pretty new far as I can see Link to comment Share on other sites More sharing options...
danzick Posted October 21, 2011 Author Share Posted October 21, 2011 the car has 260xxx on it, but supposedly its got a rebuilt motor in it. it doesn't smoke at all, and at that many miles id assume it would smoke a little if it was an old motor. and it only uses about a quart per oil change. probably leaks just about all of that quart. Link to comment Share on other sites More sharing options...
987687 Posted October 22, 2011 Share Posted October 22, 2011 What's that little filter thing by the spare tire doing?? I don't know what you've plumbed there.. but it could be causing a lean condition Link to comment Share on other sites More sharing options...
danzick Posted October 23, 2011 Author Share Posted October 23, 2011 i plugged the vent in the intake tube, and put a crank case breather filter on where the valve covers breath so my intake isnt sucking anymore oil. Link to comment Share on other sites More sharing options...
987687 Posted October 23, 2011 Share Posted October 23, 2011 danzick said: i plugged the vent in the intake tube, and put a crank case breather filter on where the valve covers breath so my intake isnt sucking anymore oil. So basically an un-metered air leak. If the PCV system is setup right it shouldn't suck oil. Link to comment Share on other sites More sharing options...
danzick Posted October 24, 2011 Author Share Posted October 24, 2011 how is it an air leak? ive got a plug in the spot where it used to go into the intake tube, and this is a crank case vent. its for venting the oil system. i have 2 of these in my 454 big block chevy. and yes, there was oil all over in the intake tube. the MAF sensor had oil all over it until i cleaned it. Link to comment Share on other sites More sharing options...
987687 Posted October 24, 2011 Share Posted October 24, 2011 danzick said: how is it an air leak? ive got a plug in the spot where it used to go into the intake tube, and this is a crank case vent. its for venting the oil system. i have 2 of these in my 454 big block chevy. and yes, there was oil all over in the intake tube. the MAF sensor had oil all over it until i cleaned it. Because metered air is escaping the system. Air comes in, exhaust goes out. Now since air is getting out somewhere besides the exhaust, that's an air leak... just sayin' Your chevy is prolly tuned to run like that. Different animal. Link to comment Share on other sites More sharing options...
