bigjimd Posted September 18, 2011 Share Posted September 18, 2011 Took a bit of fididdling and still needed to be tweeked a bit to work with the 5mt would have been fine with an at, but baby girl didn't like it. Got to come up with something different now. We put a little storage pocket in the radio cover under the radio and she keeps her Ipod there so she didn't want to loose that. The rig came out of some kinda later model Sbbie where it was mounted above the radio. Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted September 18, 2011 Share Posted September 18, 2011 Looks like a 93-97 Impreza cupholder to me. Neat that you got it to fit. The best place you will probably find is going to be down near the shifter/center console area. Or on the doors. Link to comment Share on other sites More sharing options...
SmashedGlass Posted September 19, 2011 Share Posted September 19, 2011 Yeah, I grabbed one from the P'n'P a few weeks ago from a 1g Legacy... still scratching the brain pan on how best to mount it. As low as possible is all I have figured so far Link to comment Share on other sites More sharing options...
88 EA82T Posted September 19, 2011 Share Posted September 19, 2011 I like the floor mats. Link to comment Share on other sites More sharing options...
Red92 Posted September 19, 2011 Share Posted September 19, 2011 I like the floor mats. x2! Do you have a bigger picture that shows them? Link to comment Share on other sites More sharing options...
SmashedGlass Posted September 19, 2011 Share Posted September 19, 2011 I didn't even notice them the first time I read this thread! Link to comment Share on other sites More sharing options...
bigjimd Posted September 19, 2011 Author Share Posted September 19, 2011 I like the floor mats. Thanks my baby girl made them I will tell her you like em, she redid the door cards as well. x2! Do you have a bigger picture that shows them? Here ya go. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 19, 2011 Share Posted September 19, 2011 I Like how the Green Contrasts the other Colour... Nice Subie! Link to comment Share on other sites More sharing options...
987687 Posted September 20, 2011 Share Posted September 20, 2011 My cup holder is shoving the cup between the e-brake lever and the passenger seat. It's surprisingly stable. Never had a spill. Link to comment Share on other sites More sharing options...
81EA81 Posted September 20, 2011 Share Posted September 20, 2011 Same here! sometimes its sketchy with a large hot coffee but it always gets the job done Link to comment Share on other sites More sharing options...
Dj7291993 Posted September 20, 2011 Share Posted September 20, 2011 My cup holder is shoving the cup between the e-brake lever and the passenger seat. It's surprisingly stable. Never had a spill. I remember when I could do that. Stupid 4wd lever stealing my cupholder.... I'd like to try this, but... the bushings in my shifter's linkage are, well, gone, so my shifter travels pretty far (right at the dust boot's limit for 5th), and would almost certainly hit this.I might be able to put it up higher though.... *gears start turning* Link to comment Share on other sites More sharing options...
987687 Posted September 20, 2011 Share Posted September 20, 2011 I remember when I could do that. Stupid 4wd lever stealing my cupholder.... I'd like to try this, but... the bushings in my shifter's linkage are, well, gone, so my shifter travels pretty far (right at the dust boot's limit for 5th), and would almost certainly hit this.I might be able to put it up higher though.... *gears start turning* huh? I have a 4wd d/r, and that lever doesn't get in the way any. Link to comment Share on other sites More sharing options...
jeffx Posted September 20, 2011 Share Posted September 20, 2011 EA 81 DR's fit EA 82 DR's not so much Link to comment Share on other sites More sharing options...
987687 Posted September 20, 2011 Share Posted September 20, 2011 EA 81 DR's fitEA 82 DR's not so much Maybe my 89 is just special then Link to comment Share on other sites More sharing options...
bigjimd Posted September 20, 2011 Author Share Posted September 20, 2011 (edited) I remember when I could do that. Stupid 4wd lever stealing my cupholder.... I'd like to try this, but... the bushings in my shifter's linkage are, well, gone, so my shifter travels pretty far (right at the dust boot's limit for 5th), and would almost certainly hit this.I might be able to put it up higher though.... *gears start turning* If I had pulled it in further and trimmed some of the big plastic handle it would work fine in Fizgig. There is at least 3/4" of plastic to trim and still have a handle to grab. If you take your time with the plastic and sand it smooth working up in grit it would come out presentable. I bet if you repaired the bushings this would work. The depth was dependent on where I drilled the side plates. It could have gone another 3/4" higher as well. The piece of wood was to keep tension against the rails so the slide wouldn't pull all the way out. If you tucked it right up under the radio you wouldn't need the wood. Thinking about it I bet it would work up high if you put the radio down in the lower posistion where the equalizer would fit it might work. To use it low I swapped the slides 180 and flipped the whole rig over. Then just turn the radio bezel 180 as well. Don't know didn't try that. I put it underneath so it didn't block the radio face. This is the way it mounted origionally, before it flipped it over and started wacking on it. Edited September 20, 2011 by bigjimd Link to comment Share on other sites More sharing options...
jeryst Posted September 23, 2011 Share Posted September 23, 2011 I bought some cup holders that clip onto the door. They fold up flat against the door when not is use and spring open at the touch of a button. I think I got them at a place that sells boat equipment. Unfortunately, I forgot to take them out of my 94 Loyale when I sold it, so I dont have them anymore. They worked really well, though. Link to comment Share on other sites More sharing options...
