Need a new Y pipe :(
Yeah, that's the problem; I won't have that kind of cash for a little while.
Anyhow, here's the extent of the damage, we're (have a friend who can weld exhausts) trying to assess if it can be repaired with a weld or by welding in a small section of pipe from the local parts store (cat side right):
It looks like the PO bottomed out on the left side, hitting the left manifold on something, which initially would've caused a crack. The only thing holding it together and keeping it semi quiet was the heat shield....as I discovered when I removed it to plug the "small leak" I felt :-\
