kayakertom Posted September 26, 2011 Share Posted September 26, 2011 (edited) My 88 dr wagon has recently developed a bearing noise at low rpm that goes away when driving; no noise at idle. I think it is either the pilot bearing or the release bearing. Having just switched the motor in early August, I'm not too enthused about pulling the motor again. If the noise is from either of these two bearings, what's the worst case for a failure? Any other possibility for the noise? Edited September 26, 2011 by kayakertom spelling Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted September 26, 2011 Share Posted September 26, 2011 when you clutch, it's noise as bad? kayakertom said: My 88 dr wagon has recently developed a bearing noise at low rpm that goes away when driving; no noise at idle. I think it is either the pilot bearing or the release bearing. Having just switched the motor in early August, I'm not too enthused about pulling the motor again. If the noise is from either of these two bearings, what's the worst case for a failure? Any other possibility for the noise? Link to comment Share on other sites More sharing options...
kayakertom Posted September 27, 2011 Author Share Posted September 27, 2011 Yes, more noise when the clutch pedal is pushed. Guess this points more towards the release bearing. Link to comment Share on other sites More sharing options...
nipper Posted September 27, 2011 Share Posted September 27, 2011 Well it is a noise you can ignore for a while, but it is time for a clutch. It is the throw out bearing. Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted October 10, 2011 Share Posted October 10, 2011 (edited) you need repair clutch pressure plate, clutch disc and release bearing. it's would be last longer driving. Edited October 12, 2011 by Suba_GL_87 Link to comment Share on other sites More sharing options...
nipper Posted October 11, 2011 Share Posted October 11, 2011 Suba_GL_87 said: clutch teeth worn out. even new throwing release bearing too for "case"...neeed repair clutch. ? Link to comment Share on other sites More sharing options...
kayakertom Posted October 25, 2011 Author Share Posted October 25, 2011 (edited) Update: The noise actually was coming from the power steering pump and not the clutch bearings. Had a spare power steering pump and now the noise is gone. Anyone ever rebuild a power steering pump? Edited October 25, 2011 by kayakertom spelling Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted October 26, 2011 Share Posted October 26, 2011 just replaced gasket and wheel bearing on power steering pump... Link to comment Share on other sites More sharing options...
