subie94 Posted September 28, 2011 Share Posted September 28, 2011 When i drove to Vermont with the Outback (following my buddy who was flat towing his Bronco) i filled up Concord,drove up 93 to Plymouth and took the back roads the rest of the way.by the time i got to destination,i only used 0.25 tank.the drive back home was back roads all the way.. Well when i filled back up last night,i figured out that i got approx 34 mpg (miles traveled divided by total gallons to refill) i could of sworn that highway mpg was lower the 34 and where i hardly took the highway (back road speeds varied from 35-55 though) i was wondering if since i was behind a larger vehicle,maybe being in the draft helped ?? Not complaining but i just have never had a vehicle that got that kinda mileage.. Link to comment Share on other sites More sharing options...
Gloyale Posted September 28, 2011 Share Posted September 28, 2011 Perhaps the first fill-up before you left, they topped the tank off to the brim. So while driving, the gauge stays pegged for a while, till the level drops to the normal range. Then to add to it, the fill up at the end could have been not topped off. Try again, using the same pump and method to fill. And better to do a longer trip using half the tank or more to get a more accurate calculation. Link to comment Share on other sites More sharing options...
bheinen74 Posted September 28, 2011 Share Posted September 28, 2011 Don't use the guage position to determine gallons used. You determine gallons the car drank when you pump gas the next time. If you had a full tank to begin trip, and drove, then when you fill it back to full the next gas pump, however many gallons you pump in is what your car drank up, DO not rely on a gas guage. Now with this being said, 34mpg is not out of the realm, depending on if you had a windy tailwind, headwind, crosswind, no wind, flat, slow fast, etc. Link to comment Share on other sites More sharing options...
987687 Posted September 28, 2011 Share Posted September 28, 2011 I've found the only accurate way to calculate over just one tank is to use the same gas pump at the same gas station. Hold it on full, and when it clicks off don't add anymore. Now, if you keep track of mileages and fill up amounts over the course of months, that sort of stuff gets averaged out. Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted September 29, 2011 Share Posted September 29, 2011 Its possible... I got 31 MPG in a 98 Impreza doing 70-80 MPH from Reno to Portland. Link to comment Share on other sites More sharing options...
NV Zeno Posted September 29, 2011 Share Posted September 29, 2011 Sure.. I got 32 when I took a brand new 2011 Impreza (company car) to WCSS last year. Flowmastered87GL said: Its possible... I got 31 MPG in a 98 Impreza doing 70-80 MPH from Reno to Portland. Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 29, 2011 Share Posted September 29, 2011 You get better mileage on the backroads and state highways because you are not turning 3000+ RPM all the time, and fighting 70+ mph wind. Wind resistance increases exponentially as speed increases. 15 mph and 500 rpm slower will make a big difference in fuel mileage. I get usually 33 mpg out of my 96 sedan AWD manual driving 55-60 on trips. I've been well over 400 miles on a tank on several occasions. Link to comment Share on other sites More sharing options...
nipper Posted September 29, 2011 Share Posted September 29, 2011 I can get 34 at 40mph so it may be possible Link to comment Share on other sites More sharing options...
tweety Posted September 29, 2011 Share Posted September 29, 2011 Being Australian up until 1976 we also were in miles and gallons (oz gallons which is I think a little more than US gallons). Then we went metric. Trouble has been since then that some organisations use litres per 100 kilometres, others kilometres per litre. So if you find it confusing now consider us! This was at a time when speed limits changed also. 35 mph went to 60 kph on town speed limit signs. For two decades after that I was still in my head multiplying that 60 by 6 to result in an approximate mph speed eg 36mph. Celcius temperature reading came in too. So to get an approximate Fhareinheit reading (cant be bothered with the spell check) you doubled it and added 30. eg if the forecast was for 30 degrees celcius then x2 = 60 and add 30 eg 90 degrees Far.... But some things never changed. Peoples height is suppose to me in millimetres eg 182mm but most palces still say 6foot. tyres pressures most are in psi but slowly we are getting to metric. Pity the world isnt uniform. I mean when are you guys going right hand drive anyway? Link to comment Share on other sites More sharing options...
subynut Posted October 1, 2011 Share Posted October 1, 2011 That sounds about right. My father gets 28 in town, 35 on the highway, and 30 on the interstate in his 97 legacy outback. The PandaWagon got 34 while cruising at 55, however, it drops to 25 if I'm buzzing down the interstate at 80+. Wanna go fast? You will pay for it at the pump. Wanna sip the fuel? Cruise the lesser known highways and set the cruise to no higher than 60. Link to comment Share on other sites More sharing options...
idosubaru Posted October 1, 2011 Share Posted October 1, 2011 +1 speed is huge. back roads and your buddy flat towing probably means not 70-80 mpg. like they said, slowing down makes fur huge mileage gains, but few can sustain that kind of speed for the long term so it's unusual. your suspicion about drafting may have played a roll too and a quarter tank isn't the most accurate way to do it. you don't mention auto or manual, but it's high for either one. if some of the western members tested their mileage after the end of the first long mountain pass off a fill up - they could probably get up to 80 mpg. Link to comment Share on other sites More sharing options...
subie94 Posted October 2, 2011 Author Share Posted October 2, 2011 (edited) Oops,kinda forgot about this thread.. the Outback is a 2.5,5spd fastest we went was maybe 55 for short distances then down.. yeah,i never use the gas gauge for accurate reading but just for rough idea.. should of refilled once i got to destination to figure out exactly how much gas i used compared to miles traveled.. i'm just not used to getting such high mpg..coming from a lifted jeep with a 4.0 that got maybe 16-17mpg.. oh,and i think connection for filler neck is leaking..stunk something fierce on the way up to VT till gas level went down.. Edited October 2, 2011 by subie94 Link to comment Share on other sites More sharing options...
Crawlerdan Posted October 2, 2011 Share Posted October 2, 2011 my old lexus averaged 26- driving calmly behing a u haul for 400 miles it did 32 my lifted 4runner does 18 ave, did 24.5 behind large u haul for 800 miles....i move alot Link to comment Share on other sites More sharing options...
