Mykeys Toy Posted October 2, 2011 Share Posted October 2, 2011 (edited) Title says it all how do you tell if there are no stickers on the valve covers for whatever reason? what would I be looking for with the covers off that would indicate such. Revision My 82/83 sedan is the noisiest engine in a sube I have ever had. I thought to adjust the valves but you don't adjust Hyd lifter motors and there are no stickers on the valve covers. I just dont want to screw it up by adjusting something not meant to be adjusted. Edited October 2, 2011 by Mykeys Toy cant freakin type today Link to comment Share on other sites More sharing options...
GLCraig Posted October 2, 2011 Share Posted October 2, 2011 When you pull off the valve covers there are a couple of things to look for. Look at the lock nut for the rocker arm adjustment. Hydro lifter engines will have locking tabs to keep the nut from backing loose. Look at the push rods. Hydro lifter engines push rods are steel. Solid lifter engines have aluminum push rods with a steel tip. Link to comment Share on other sites More sharing options...
Mykeys Toy Posted October 2, 2011 Author Share Posted October 2, 2011 steel vs aluminum and lock tabs..thanks now to find time. Link to comment Share on other sites More sharing options...
