nipper Posted October 2, 2011 Share Posted October 2, 2011 Here in NY older cars only go through a tail pipe test. The Justy has an air injector right after the cat (which is bolted onto the exhaust manifold). The replacement system has a modern three way cat that goes where the single stage cat is now (think resonator type placement). I have to loose the air injector for the replacement system. Those who have removed the air injector, do you still pass(non CA) emissions? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 2, 2011 Share Posted October 2, 2011 I have seen it work that way on EA's - not specifically Justy's but I have seen people eliminate the AIS system with the installation of a new cat and pass smog without a problem. The new cat's don't need that system. GD Quote Link to comment Share on other sites More sharing options...
nipper Posted October 3, 2011 Author Share Posted October 3, 2011 That is what I thought, thanks. It is basically the same system as other 80's vehicals, just the justy has an oddball cat and i wasnt sure. All elose fails it is an OBD1 system and my mechanic has always been good at *ahem* guiding older vehicals through inspections Quote Link to comment Share on other sites More sharing options...
