soloz2 Posted October 4, 2011 Share Posted October 4, 2011 I've seen quite a few threads on rebuilding older Subaru starters, but not much on the newer cars. The starter on my 06 does not disengage as quickly as it should. I understand this is a fairly common problem on the 4th Gen Legacies. I have also read that taking the starter apart and greasing it up will fix this issue without the expense of buying a new starter. Here is a video where you can hear the noise the starter makes. This is not my video, but the noise is the same. I have never done anything like this and have a few questions. 1. What type of grease would be best? 2. Where can I get new contacts and a plunger? I plan to replace these parts as they will be easily accessible while the starter is out of the car. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 4, 2011 Share Posted October 4, 2011 Check with the dealer on a contact kit for it. I would probably use some form of Lithium Complex (white or off-white) grease. That is the most common thing to find in small gear drive's like starters and wiper motors, etc. Lubriplate makes some really good quality mil-spec stuff. GD Quote Link to comment Share on other sites More sharing options...
soloz2 Posted October 7, 2011 Author Share Posted October 7, 2011 Just called my local dealer and they told me that i couldnt just get contacts and the plunger and would have to buy a new starter. Any one know the part numbers? Quote Link to comment Share on other sites More sharing options...
soloz2 Posted October 8, 2011 Author Share Posted October 8, 2011 Looking at Opposed Forces; the illustration looks different than the pictures I have seen of starters before. http://opposedforces.com/parts/legacy/us_b13/type_1/engine_electronic/starter/illustration_1/ No 14 is called a plunger and No 17 is called a plate. Looking at the picture leaves me somewhat confused. Quote Link to comment Share on other sites More sharing options...
Whitedog Posted October 30, 2011 Share Posted October 30, 2011 Looking at Opposed Forces; the illustration looks different than the pictures I have seen of starters before. http://opposedforces.com/parts/legacy/us_b13/type_1/engine_electronic/starter/illustration_1/ No 14 is called a plunger and No 17 is called a plate. Looking at the picture leaves me somewhat confused. the contacts and plate are not #14 and #17, but is it #10? I don't know and hope someone can help us with this. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 30, 2011 Share Posted October 30, 2011 (edited) Looks like Subaru breaks it down to just the "Switch assembly-magnetic, starter" which is #7. Runs about $70 or so it looks like. Cheaper than a new starter at least! But if you figure out which denso starter model it is - you should be able to buy the contacts online. I've seen them for sale and looked into it before. GD Edited October 30, 2011 by GeneralDisorder Quote Link to comment Share on other sites More sharing options...
Olnick Posted October 30, 2011 Share Posted October 30, 2011 Assuming that starters haven't changed too much since I worked on my '95 Legacy, I suggest you remove the starter and open up the back of the solenoid. Take out the two L-shaped semi-circular copper contacts and carry them with you to a local auto-electric shop--there are a number of configurations so you want to make a visual confirmation! Contacts should be $15 or less. You probably don't need to replace the plunger (the large copper "washer")--just dress the face with emory paper. Ask a local mechanic what auto-electric shop he uses--there's usually a well respected one in every town. If that doesn't work check with Toyota or other major dealers. Or look online or maybe Ebay. Good luck. Quote Link to comment Share on other sites More sharing options...
Whitedog Posted October 30, 2011 Share Posted October 30, 2011 Looks like Subaru breaks it down to just the "Switch assembly-magnetic, starter" which is #7. Runs about $70 or so it looks like. Cheaper than a new starter at least! But if you figure out which denso starter model it is - you should be able to buy the contacts online. I've seen them for sale and looked into it before. GD Ah. I see that now. #10 is parts where the solenoid mounts to the body. I have a couple of starter shops in town to source parts. Hopefully I will remember to post up some numbers for others to work with. Quote Link to comment Share on other sites More sharing options...
soloz2 Posted October 30, 2011 Author Share Posted October 30, 2011 Just an update. I was able to grab a starter of an 05 LGT 5MT for $50 shipped. It just arrived Friday, but I haven't had the chance to look at the model or anything like that. I plan to pull it apart, clean it, grease it (if needed) and just do a straight swap. Since I couldn't find the parts and I don't have a garage I figured it would be easier to just swap than to pull, try and source parts come back and install again. Quote Link to comment Share on other sites More sharing options...
soloz2 Posted November 10, 2011 Author Share Posted November 10, 2011 Here's some pics showing the PN. It is a Denso starter. Where should I look for parts. This one suspisedly works just fine, but while its out as long as new contacts arent too expensive I'll replace them. Quote Link to comment Share on other sites More sharing options...
hohieu Posted November 10, 2011 Share Posted November 10, 2011 The new Denso starters look like they went with the sealed solenoid as well. While it's possible to rebuild the solenoid, it's not as easy as with the older Denso starter/solenoid assemblies. It seems like most suppliers only sell parts to electrical parts rebuilders, but there's a guy on ebay, probably a rebuilder himself, who sells the solenoids. Check out my post in this thread: http://www.ultimatesubaru.org/forum/showthread.php?t=127583&page=2 Quote Link to comment Share on other sites More sharing options...
