Clutch replacement question.
The clutch on my ea81 swapped 89GL is getting tired and I just want to make completely sure about the step.
It's using all ea82 stuff, flywheel, disc, pressure plate, etc.
Searching the forum I found 0.815" as a number for the flywheel step, is this correct?
With this setup, I should be able to just use a standard sachs (or whatever other brand) clutch kit for a 4wd loyale, right?
Oh, also. All pilot bearings are the same, right? I have a brand new one for an EJ flywheel.
