Advice on 14" pugs? 504 steels or alloys?
I know there are tons of threads but I need some quick advice. I finally got a local seller with 14" pugs :banana:
I can choose between the old 504 steels (non-beveled lug hole with weird washer lugnut) or the 14" alloys. the price is the same, seller has some lugnuts for either, but probably not a complete set for either. So obviously lugnut availability will be a challenge...but with new rubber on my 13s, I'm not in a rush.
http://www.indysworld.com/80s/general/wheels/wheels.html#pug14
steel sounds more durable but those old lugs w/washers seem sketchy and near impossible to find. anybody ever run these 504 wheels without the original nuts? He may have a complete set for these.
alloy might look nicer (depending on condition), but may be less durable. he probably has fewer lugs and few if any center caps.
Thanks a heap.
I think the 504 steelies are generally to be avoided because they need to be balanced with a special hard-to-locate machine after the tires are installed. If they are the steelies with the small hole in the center, then I think you want to stay away from them and go with the alloys. Options are available for the alloy wheel lugnuts.
