SubieTony77 Posted October 8, 2011 Share Posted October 8, 2011 OK, I need some help, I have a 2002 Impreza Outback Sport, and my drivers window does not work, it is not the switch, and I would assume that the relay is bad. If anybody has any ideas on what else to check, or where the relay is located, I would really appreciate it. Link to comment Share on other sites More sharing options...
ocei77 Posted October 8, 2011 Share Posted October 8, 2011 Go to this link http://www.bustedfingermotorsports.com/forums/viewtopic.php?f=18&t=168&sid=3a21f199211d05e86db1cee1d2824a45 look up electrical section and go from there. O. Link to comment Share on other sites More sharing options...
Cougar Posted October 9, 2011 Share Posted October 9, 2011 There isn't an individual relay for the windows. Either the wiring to the motor is broken somewhere, the motor is bad, or it is jammed. Link to comment Share on other sites More sharing options...
SubieTony77 Posted October 11, 2011 Author Share Posted October 11, 2011 ocei77, I will check it out, and Cougar, or whoever else reads this, when I hit the window switch it doesn't make any noises or clicks, it is as if it is not connected. So I will check the motor, thanks for your help. Link to comment Share on other sites More sharing options...
Cougar Posted October 11, 2011 Share Posted October 11, 2011 I'm not sure why you say that the switch can't be the trouble because in most cases that it is where the trouble is. So if you haven't verified the that the switch is ok by testing it I suggest you do that. Link to comment Share on other sites More sharing options...
SubieTony77 Posted October 25, 2011 Author Share Posted October 25, 2011 Cougar, the switch was one of the first things that I checked and replaced, they are notorious for going bad, however, it was a connector that came apart inside the door. There was a window replacement TSB about the new wiring being shorter than the original and it could work itself loose, and it did. That was the problem, thank you everybody for your help. Link to comment Share on other sites More sharing options...
bigbloody Posted August 26, 2013 Share Posted August 26, 2013 Anybody know where window relay is on 1994 legacy. The parts houses have them for sale and I thought it was under passenger seat but I haven't found it. Link to comment Share on other sites More sharing options...
Magauto Posted August 26, 2013 Share Posted August 26, 2013 Have you figured out the problem with your window? If your other windows work off there switches then it has to be the wiring or the main switch itself. If the fuse was blown or bad none of the windows would work at all, being that they are all on the same fuse. So if you check your other window switches and they work you know at that point that it is not your fuse's. I would suggest for you to go to a junk yard and pull out a main switch from the driver side door and try that or you can always purchase one here: http://www.subieparts.com This is my go to website for anything part related. Just hit the OEM catalog and search for what you need in there! If after that it still wont work then you have to dig deeper and find the entirety of the wiring and make sure that it is still all hooked up and working properly! Let me know how you make out! Link to comment Share on other sites More sharing options...
ivans imports Posted August 26, 2013 Share Posted August 26, 2013 test motor Link to comment Share on other sites More sharing options...
Turbone Posted August 26, 2013 Share Posted August 26, 2013 Anybody know where window relay is on 1994 legacy. The parts houses have them for sale and I thought it was under passenger seat but I haven't found it. Please start another thread for this, most people wont come here and look and if they do they might not even reply to your request. Have you figured out the problem with your window? If your other windows work off there switches then it has to be the wiring or the main switch itself. If the fuse was blown or bad none of the windows would work at all, being that they are all on the same fuse. So if you check your other window switches and they work you know at that point that it is not your fuse's. I would suggest for you to go to a junk yard and pull out a main switch from the driver side door and try that or you can always purchase one here: http://www.subieparts.com This is my go to website for anything part related. Just hit the OEM catalog and search for what you need in there! If after that it still wont work then you have to dig deeper and find the entirety of the wiring and make sure that it is still all hooked up and working properly! Let me know how you make out! Please keep your web store promotions in the appropriate forum (Vendors) Link to comment Share on other sites More sharing options...
Turbone Posted August 26, 2013 Share Posted August 26, 2013 test motor Read up a couple of posts, he fixed the problem. Link to comment Share on other sites More sharing options...
