2.2 timing belt install question
  Sabaroo said:
So I got my heads rebuilt & installed, my question is how do you rotate the cam gears and crank so as not to cause valve damage when lining up marks? It is an interference motor.
If you line up the mark on the crank pully it puts all the pistons in the middle. So you can turn the cams all day long and you won't get interference.
  TOsborn said:
The EJ22 (assuming that is the motor you are referencing with 2.2) is a non interference engine. You can sping the cam all day long with the piston at TDC and not cause any problems.
Wrong. 97 and above the 2.2 IS an interference engine.
