gear ratios??? help plz
ok i got a 87 gl-10 wagon turbo 5 spd the guy i bought it from put a dual range tranny in it. the rear axle seems to have a different ratio it says 3.70 my question is what ratio does the dualrange have? its a fwd 4hi 4 low selectable. the car seems to fight itself on pavement im wondering if this will cause problems aside from winter and camping i dont use 4wd but also if the rear ratio is higher wont the rear kick out easyier?.. im rambling. any responses will be greatly apprieciated.
