cal_look_zero Posted October 11, 2011 Share Posted October 11, 2011 1992 Subaru Loyale; 332k Been driving the Subi every day now, put probably 250 miles on it since the HG replacement. Fixing little things here and there, but I think I have an issue; possibly severe; with the cat. The HGs were gone long before I got to the car. Little copper flecks all over the radiator cap, in the coolant, and all over internally; someone ran some HG fix through the cooling system. Lots and lots of oil residue on the passenger side cross member and the cat was totally coated. Long story short, I noticed a decent sized oil mark in the driveway. Nasty burnt smelling black oil. The oil in the engine is right where it should be, and still transparent and decent smelling, so I know it's not the engine. I looked at the back of the cat, and it was dripping oil and had a lot of residue still on it. Cut to the chase; is it feasible that a ton of oil collected in the cat from the HGs being gone, caused it to flow horribly and pop a seam, and is leaking said oil now? And if so, how do these engines take to a more open exhaust from the y pipe on back? Probably cheaper to have a 2" catless with a nice throaty muffler built, than to replace the cat itself. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 11, 2011 Share Posted October 11, 2011 ...how do these engines take to a more open exhaust from the y pipe on back? ... Those EA82's Takes a Little bit Less Restrictive Exhaust Very Good! ... I Run my Weberized EA82 with a Catless "Y" Pipe since 1993 without any Problem, also it seems to Help the engine to gain a Little extra acceleration. Kind Regards. Quote Link to comment Share on other sites More sharing options...
cal_look_zero Posted October 11, 2011 Author Share Posted October 11, 2011 Those EA82's Takes a Little bit Less Restrictive Exhaust Very Good! ... I Run my Weberized EA82 with a Catless "Y" Pipe since 1993 without any Problem, also it seems to Help the engine to gain a Little extra acceleration. Kind Regards. Sounds like the way to go then. I don't have to pass emissions, so I'm more inclined to get a little more oomph out of the engine as well as a better exhaust note. Quote Link to comment Share on other sites More sharing options...
