So this is my situation. I have a 98 outback and I had a Legacy GT bumper painted grey to match and installed it. For years, I just had the little plastic insert things instead of the square fog lights. I scored a really nice pair of stock GT foglights but the connector from the Outback fogs doesn't fit into the connector on the GT fogs.
So yeah, is there a type of universal connector that I can purchase and just cut the two ends off and use an aftermarket connector to wire these up to the stock wiring?
I hope this makes sense to someone!
Thanks you guys!
What bulb does the GT fog light use? If the connector plugs straight into the back of the bulb, look for a pigtail connector for that bulb.
Some bulbs you can find wire pigtails at local parts stores. Others you might have to order on ebay or something.
It's not like a headlight bulb socket, it's like a pigtail that extends from the cover of the back of the light. Was hoping there was a product that I could insert the cut wires into with a both male and female side so I am able to change the bulbs.
Thanks.
