My fogs have never worked. I figured maybe it was just the bulbs.
Wrong.
I installed new ones yesterday and they still don't work. The switch works. It lights up and everything.
Anyone have insight to the problem? I'm guessing the wiring is bad somewhere, but on both lights? Doesn't seem right. I tihnk perhaps I'm missing something important.
:wave: have you checked for power at the lights? if there is no power there check the fuse and the relay one or both may be bad. also check the wiring from the light switch as if these are factory there only on with the low beems:burnout:
