NikFu S. Posted March 14, 2004 Share Posted March 14, 2004 My fogs have never worked. I figured maybe it was just the bulbs. Wrong. I installed new ones yesterday and they still don't work. The switch works. It lights up and everything. Anyone have insight to the problem? I'm guessing the wiring is bad somewhere, but on both lights? Doesn't seem right. I tihnk perhaps I'm missing something important. Link to comment Share on other sites More sharing options...
scubaroo Posted March 14, 2004 Share Posted March 14, 2004 :wave: have you checked for power at the lights? if there is no power there check the fuse and the relay one or both may be bad. also check the wiring from the light switch as if these are factory there only on with the low beems:burnout: Link to comment Share on other sites More sharing options...
NikFu S. Posted March 15, 2004 Author Share Posted March 15, 2004 All my fuses and relays are good. The switch is good and they don't come on with any combo of his or lows ignition or not. I'll have to check the actual wiring Tuesday when I have a minute. Link to comment Share on other sites More sharing options...
