SmashedGlass Posted October 20, 2011 Share Posted October 20, 2011 How long are the 3/16" roll pins in the half shafts? I found 3/16" pins at work, in 1" and 1-1/2" lengths and thinking of grabbing them as 'insurance' for when I do the bearings.... Link to comment Share on other sites More sharing options...
Caboobaroo Posted October 20, 2011 Share Posted October 20, 2011 No... Just go to the dealer and spend the couple bucks to buy the correct ones. Many times have I seen aftermarket roll pins break off in the stubs while removing them, and that's using the correct tool! I actually have about a dozen of them in my toolbox at work and also keep new ones in stock. Link to comment Share on other sites More sharing options...
ferox Posted October 21, 2011 Share Posted October 21, 2011 How long are the 3/16" roll pins in the half shafts? I found 3/16" pins at work, in 1" and 1-1/2" lengths and thinking of grabbing them as 'insurance' for when I do the bearings.... They are 5 mm x 45 mm. I had the same idea (using Standard) as you when I first started working on these cars and as Caboobaroo said they are not an option. Dealer or a Subaru mechanic will also probably have a box of them and will sell you a few. Link to comment Share on other sites More sharing options...
man on the moon Posted October 21, 2011 Share Posted October 21, 2011 Some axle replacement sets will come with a roll pin, check the details on the one you are planning to purchase. Link to comment Share on other sites More sharing options...
SmashedGlass Posted October 21, 2011 Author Share Posted October 21, 2011 So they're a bit too short (45mm=1 3/4"+). Oh well. Durability of these pins wasn't an issue; they're the ones we use on our armored tracked vehicles like the M1 and the Bradley :-p Link to comment Share on other sites More sharing options...
ferox Posted October 21, 2011 Share Posted October 21, 2011 Durability of these pins wasn't an issue Actually it was a size issue when I tried them (I realize Caboobaroo mentioned breakage), diameters were too small or large. Link to comment Share on other sites More sharing options...
edrach Posted October 22, 2011 Share Posted October 22, 2011 I always re-use the old ones. I always save the pins when I pull axles at the PicknPull yard. Over the years I've acquired quite a few spares. Link to comment Share on other sites More sharing options...
Caboobaroo Posted October 22, 2011 Share Posted October 22, 2011 Most aftermarket axles do come with pins but they're not usually as exact as the OEM ones. OEM axle pins are made to work over and over again (which is probably cut in a zig zag form) versus the aftermarket ones which are straight cut and squish more then compress. Link to comment Share on other sites More sharing options...
