cmill189 Posted October 21, 2011 Share Posted October 21, 2011 So I came across a listing on ebay for a new Beck/Arnley oil pump for $23. I figured someone forgot to type a 1 in front of the 2, so I bought it. What showed up was a Paraut brand. I figured anything is better than the one I just re-installed that didn't meet spec and had gouged rotors. A second question I pulled all the covers off when I did belts/seals/etc. Is it possible to slip the drivers-side timing belt off the idler, and then off the oil pump, all while leaving everything else in place? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 21, 2011 Share Posted October 21, 2011 Paraut is one of the OEM manufacturers. If you look at the pump it likely will say Aisin on it. But either way both are Japanese and inter-related brands. A long time ago I bought a Paraut branded pump and it was OEM inside the box. There aren't any aftermarket makers of oil pumps for EA engines that I have ever seen. So if you got an oil pump at all - it's OEM. You may be able to do just the drivers side belt - only thing you can do is try. GD Quote Link to comment Share on other sites More sharing options...
silverhelme Posted October 22, 2011 Share Posted October 22, 2011 You still have to pull the center cover but yes you can pull the drivers belt and do the oil pump without pulling the other side. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted October 22, 2011 Share Posted October 22, 2011 If it was me, I would pull both belts and check the rollers with it that far apart to make sure I don't have one going bad. Quote Link to comment Share on other sites More sharing options...
cmill189 Posted October 23, 2011 Author Share Posted October 23, 2011 All of the timing belt covers were left off when I changed the belts. Both tensioners and the idler were replaced with new as well; the suspected originals were beyond worn out! Thanks for the help everyone. Quote Link to comment Share on other sites More sharing options...
