Moosen Posted October 23, 2011 Share Posted October 23, 2011 I think I have asked this before but not sure. Was just watching some GL-10 videos on youtube and those things mob! How easy would it be to drop a turbo onto my 87 gl EA82? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted October 23, 2011 Share Posted October 23, 2011 easy if you have a donor car. hard if you need to find a harness, a crossmember, and other turbo related bits. hardest if going from carb. hardest for 87 unless all your (harness, ecu, manifild) parts are from 87. for the same labor and expense, you can go with any legacy or impreza 2.2 na and still have 25 mpre hp than an ea82t, without all the associated troubles with ea82t. it is the easiast to start with an already ea82t cat to begin with if you are a fan of ea82t Quote Link to comment Share on other sites More sharing options...
Moosen Posted October 23, 2011 Author Share Posted October 23, 2011 easy if you have a donor car. hard if you need to find a harness, a crossmember, and other turbo related bits. hardest if going from carb. hardest for 87 unless all your (harness, ecu, manifild) parts are from 87. for the same labor and expense, you can go with any legacy or impreza 2.2 na and still have 25 mpre hp than an ea82t, without all the associated troubles with ea82t. it is the easiast to start with an already ea82t cat to begin with if you are a fan of ea82t http://www.ultimatesubaru.org/forum/showthread.php?t=126592 answered it hahaha. damn i would love to do the ej22 but at that point i would just get a new car. seems too hard for me Quote Link to comment Share on other sites More sharing options...
MilesFox Posted October 23, 2011 Share Posted October 23, 2011 This stuff can be done, and it would be interesting to do, but it is only worth it if you have donor cars laying around, plenty of experience, and then only for the sake of novelty. Realistically a weber carb on your carb manifols with an spfi longblock(higher compression), open exhaust, advanced timing would give a goo kick in the pants. IF you blow a head gasket, that is a good chance to go with an spfi block, even with your same heads. the spfi engine block is a direct swap in with no mods, and the carb manifold fits the same. you may have to block off egr ports. this is ultimately the easiest to do for the amount of parts, labor, and expertise required. Quote Link to comment Share on other sites More sharing options...
Moosen Posted October 23, 2011 Author Share Posted October 23, 2011 This stuff can be done, and it would be interesting to do, but it is only worth it if you have donor cars laying around, plenty of experience, and then only for the sake of novelty. Realistically a weber carb on your carb manifols with an spfi longblock(higher compression), open exhaust, advanced timing would give a goo kick in the pants. IF you blow a head gasket, that is a good chance to go with an spfi block, even with your same heads. the spfi engine block is a direct swap in with no mods, and the carb manifold fits the same. you may have to block off egr ports. this is ultimately the easiest to do for the amount of parts, labor, and expertise required. And yet i still dont know what you are really talking about Quote Link to comment Share on other sites More sharing options...
6 Star Posted October 23, 2011 Share Posted October 23, 2011 And yet i still dont know what you are really talking about Fox is saying you can make some power changes with stuff thats more easy to get your hands on. EA82T's are notorious for problems anyway. You can easily make just as much horsepower with a weber carb upgrade to your car. I did not know that spfi blocks have more compression... I will look into that when I rebuild my wagon. Quote Link to comment Share on other sites More sharing options...
Moosen Posted October 23, 2011 Author Share Posted October 23, 2011 Fox is saying you can make some power changes with stuff thats more easy to get your hands on. EA82T's are notorious for problems anyway. You can easily make just as much horsepower with a weber carb upgrade to your car.I did not know that spfi longblocks have more compression... I will look into that when I rebuild my wagon. Numbers? about how much more hp? Quote Link to comment Share on other sites More sharing options...
6 Star Posted October 23, 2011 Share Posted October 23, 2011 Not sure as far as numbers go. Quote Link to comment Share on other sites More sharing options...
Moosen Posted October 23, 2011 Author Share Posted October 23, 2011 Not sure as far as numbers go. Agh i want a weber! so expensive! Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 23, 2011 Share Posted October 23, 2011 If you consider a Weber to be expensive (it's about $250, give or take, to install a used one and all the correct plumbing), then asking about turbo swaps or engine swaps (which rarely come in under $1000) is pretty silly isn't it? GD Quote Link to comment Share on other sites More sharing options...
MilesFox Posted October 23, 2011 Share Posted October 23, 2011 be happy with the car now the way it is at least for now, or you will never be happy with anything. the car may seem disappointing compared to other cars, but there is a lot there to amaze you yet. it's a different cup of tea with these cars:burnout: Quote Link to comment Share on other sites More sharing options...
Moosen Posted October 23, 2011 Author Share Posted October 23, 2011 If you consider a Weber to be expensive (it's about $250, give or take, to install a used one and all the correct plumbing), then asking about turbo swaps or engine swaps (which rarely come in under $1000) is pretty silly isn't it? GD Where can you get a used one for 250?! Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 23, 2011 Share Posted October 23, 2011 Craiglist, etc. A local guy just had me help install a Weber that he bought from some dude off an MGB for $65. Was in great condition. GD Quote Link to comment Share on other sites More sharing options...
bonvo Posted October 23, 2011 Share Posted October 23, 2011 Where can you get a used one for 250?! you just have to look around dude i got one for 80 bucks for my datsun you just have to look Quote Link to comment Share on other sites More sharing options...
