...also has been sold modified to look like the dodge van!...
...or chevy van...
...i really like that mini dodge and mini chevy look!
kind regards.
I SO want either that dodge or chevy look-a-like!
edit: apparently the pics don't want to quote... hmm..
My, that's one custom off-road Suby! :slobber: Is there anything left that's still Subaru under the hood?
Your answer:
This car is running a Saturn 1.9L, DOHC, Toyota 5-speed transmission, Marlin crawler box, and a Toyota t-case with 4:1 marlin gear set. It also has the upgraded main shaft. 4-link front and rear suspension with Sway-a-way coil overs, custom Dana 44 front with alloy shafts, welded and full hydro steering. Custom 9" rear with moser shafts, lockrite. 5.13 gears. This car is 217:1 final drive in low-low range. It is a full tube chassis with a subaru wagon skin/body. It is currently sitting on 35" Maxxis Treppadors, competition compound. They are very soft and get traction nearly everywhere. Car also had an older Warn M5 winch that works very well and is loaded with Amsteel Blue synthetic winch rope. It is built into the front end of the car so it is tucked up nice and tight, out of the way.
Here is the build thread:
http://www.colorado4x4.org/vbb/showthread.php?t=109844&highlight=Stupidru
