the3rsss Posted October 26, 2011 Share Posted October 26, 2011 I am having a hell of a time finding the correct hoses for this (99 obw 2.5) auto. Ordered them from gates but they were wrong! Don't want to go to the dealer. Can I just bypass them? Will it effect my warm-up or anything else? Can't figure out why they would want to heat up the tb. What do you guys think? Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted October 27, 2011 Share Posted October 27, 2011 The IACV and TB can start to ice up under the right conditions, so that's why coolant passes through them. I picked up one of those hoses from Subaru dealer online, it was about $10 for the return one. Quote Link to comment Share on other sites More sharing options...
lmdew Posted October 27, 2011 Share Posted October 27, 2011 You can also just use 3/8" rubber hose. Hyd Transmission hose is good. Quote Link to comment Share on other sites More sharing options...
sario Posted October 27, 2011 Share Posted October 27, 2011 I am having a hell of a time finding the correct hoses for this (99 obw 2.5) auto. Ordered them from gates but they were wrong! Don't want to go to the dealer. Can I just bypass them? Will it effect my warm-up or anything else? Can't figure out why they would want to heat up the tb. What do you guys think? Mine have been bypassed for years. I'm not saying it's a good ideal, just that i personally haven't had any problems. I can't remember why i did it though, i think one of the hoses had a leak and it was just going to be a "temporary repair" Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted October 27, 2011 Share Posted October 27, 2011 The dealer should have them and they're fairly cheap. I typically replace them one out of 10 headgasket jobs I do here at the shop. Quote Link to comment Share on other sites More sharing options...
newsoobdude Posted October 28, 2011 Share Posted October 28, 2011 I removed mine years ago and have not had any problems with it since. Been in the snow and cold as well as uber hot and no problems. Just wait a couple seconds in super cold temps before taking off in the car to make sure no icing over. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted October 28, 2011 Share Posted October 28, 2011 Right at startup it isn't going to make any difference since the coolant is at ambient anyway. The thing with the IACV and throttle is that it is air passing through an orifice, so there is a temperature drop associated with it. So it would probably be most likely to ice up in high humidity with the temperatures just above freezing. After the vehicle is up to operating temperature there might be enough heat coming off the engine to keep it uniced. I don't know if it matters a little ice, I wonder if there were ice on the throttle butterfly and it came off suddenly if it could get stuck under an intake valve. I mean it would melt fast but could be enough time for the piston to hit it in the interference engines? Quote Link to comment Share on other sites More sharing options...
987687 Posted October 28, 2011 Share Posted October 28, 2011 I have a friend who lives in sweeden. He's a nut job, and in the winter rides a dirt bike with spiked tires. His doesn't have coolant through the carb and he's actually had it freeze up on him more than once, sticking the throttle open. Living in a cold climate, I'd probably keep the coolant lines there. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted October 28, 2011 Share Posted October 28, 2011 Its okay to attempt to avoid the dealer but sometimes its just easier and the quality is usually certain along with the parts are right almost every time if you bring your Vin number with you. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 28, 2011 Share Posted October 28, 2011 i've bypassed the coolant lines before - no issues. i figure it's *more reliable* since there are fewer connections/clamps. i've never seen those leak. i doubt it matters what you do. i've also used generic hose, looks like larry knows the size. Quote Link to comment Share on other sites More sharing options...
the3rsss Posted October 28, 2011 Author Share Posted October 28, 2011 I can't get regular hose to work. The bends are way to tight. Went to order at the dealer and he cent even find them! Anyone have part numbers? Got to say, subaru dealer part computer program sucks. Shows every hose at the intake ( vac etc) and just lables each as "hose". Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted October 28, 2011 Share Posted October 28, 2011 Anymore they're kid of generic even from the dealer. The bends are close but not going to be a direct match to the originals. Still, never had an issue. The PN I use at work is 807607332 Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 29, 2011 Share Posted October 29, 2011 I had a hell of a time finding replacements for these last year. Subaru uses the same hose for two sides of the "loop". It looks like it won't work on the IAC side, but it does once the hose is installed. Kinda hokey, but it works and it's cheap at just 6.00 list price. Get Two of these: 807607190 And get One of these: 21144AA001 Quote Link to comment Share on other sites More sharing options...
