variant13 Posted October 28, 2011 Share Posted October 28, 2011 Huh, what? I love old owner's manuals, just got one for my 84 GL, and it goes into such detail. Tells me how to adjust valves... It's just crazy. BUT - do I really have vehicle posture adjustments? This seems extremely useful to me, as I had been thinking of seeing if I could juuuust squeeze a titch more clearance out of Sadie... Thoughts? Link to comment Share on other sites More sharing options...
l75eya Posted October 28, 2011 Share Posted October 28, 2011 I read somewhere in my haynes manual there is a way to adjust the clearance of the vehicle at all four corners. I think it's adjustable, just not sure how to do it. Others can correct me if I'm wrong. Link to comment Share on other sites More sharing options...
wentz912 Posted October 28, 2011 Share Posted October 28, 2011 I know my 85 has collars on the rear shocks that are adjustable for ride height like the old dual shock dirt bikes were. Can't speak for the EA81 cars. Link to comment Share on other sites More sharing options...
gadberry Posted October 28, 2011 Share Posted October 28, 2011 The 'posture adjustment' instructions should be in your owners manual too. I've not done the procedure yet, so I hesitate to describe the where/how but I'm pretty sure I've seen it in my Owners Manual. I'll double-check my Factory service manual tonight too. Link to comment Share on other sites More sharing options...
81EA81 Posted October 28, 2011 Share Posted October 28, 2011 On an EA81 the front adjusters are on the strut.look in your wheel well and it will be right above your tire. 2 nuts per strut, 21 mm head. turn them equally one turn at a time.I believe it gives about an inch of extra clearance for the rear theres only one bolt. wagons lift the back seat and remove the center rubber plug you will see a bolt on the torsion bar right in the middle. Brat simply crawl under. Plenty of room under there and yes it is in the owners manual Link to comment Share on other sites More sharing options...
bratman2 Posted October 29, 2011 Share Posted October 29, 2011 You can use it but it should be temporary as it throws the toe-in alignment out! Other words it will accelerate front tire wear. Link to comment Share on other sites More sharing options...
