SuperBrat Posted November 1, 2011 Share Posted November 1, 2011 89 hatchback last year made 1800 4 speed when car is warm after 15 minute drive car wont start but WILL start with starting fluid? What am i up against with this problem? Link to comment Share on other sites More sharing options...
idosubaru Posted November 1, 2011 Share Posted November 1, 2011 (edited) what's the condition/history of the carburetor? i would lean towards that but folks more familiar with them will hopefully chime in shortly. does it do this every time, often, or it's just done it once or twice? trying to determine if the 15 minutes is a consistent symptom. doubt it's the case here but it's not impossible for fuel pumps to tweak when heated up. fuel filter - equally unlikely since i wouldn't expect it to be so predictable with the 15 minute thing. Edited November 1, 2011 by grossgary Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 1, 2011 Share Posted November 1, 2011 Typically this is related to a weak ignition in my experience. The lean mixture of a warm carb is difficult to ignite if the ignition is weak. Last time I saw this a new ignition coil fixed it right up. Check/test all your ignition parts. GD Link to comment Share on other sites More sharing options...
bheinen74 Posted November 1, 2011 Share Posted November 1, 2011 something with the choke or carb? maybe it is not opening fully when warm. Link to comment Share on other sites More sharing options...
Quidam Posted November 1, 2011 Share Posted November 1, 2011 89 hatchback last year made 1800 4 speed when car is warm after 15 minute drive car wont start but WILL start with starting fluid? What am i up against with this problem? If you're running 10% alcohol fuel, that's a factor. Your jets were calibrated for different gasoline then you can buy today. So, it's probably lean. Doug Link to comment Share on other sites More sharing options...
SuperBrat Posted November 1, 2011 Author Share Posted November 1, 2011 Bought this car this way, from second owner car is near mint condition, the carb was rebuilt new fuel filter, i did notice the rpm guage would jump a little at idle like the distributor was going but why will it start with starting fluid after a drive when warmed up? Now with this info does it make any sense? I was thinking weak fuel pump at first now i dont know Link to comment Share on other sites More sharing options...
Quidam Posted November 1, 2011 Share Posted November 1, 2011 The tach thing is probably something going on. Can you see/smell fuel if you "pump" the throtle lever, before you add starting fluid? Can you see a shot of fuel from the accelerator pump? Once you pump it a few times, can you see fuel vapor comming out the top of the carb? Doug Link to comment Share on other sites More sharing options...
SuperBrat Posted November 1, 2011 Author Share Posted November 1, 2011 Thanks doug, ill check that and i do have a couple coils i can swap out Link to comment Share on other sites More sharing options...
nipper Posted November 2, 2011 Share Posted November 2, 2011 Will it keep running after it has restarted? Link to comment Share on other sites More sharing options...
SuperBrat Posted November 2, 2011 Author Share Posted November 2, 2011 Yes it will, will not start after shutting off after warming up Link to comment Share on other sites More sharing options...
nipper Posted November 2, 2011 Share Posted November 2, 2011 Try this: Crank the engine for a few seconds with no throttle. Gently press the gas pedal 1/3 way down and hopefully it should start. rev the engine a little for ten seconds. The engine may run a little rough once it starts. Let me know. Link to comment Share on other sites More sharing options...
