Any interest? OEM EA radio ponderings
Sure, pin out for the headunit side of the DIN is:
From left to right
White - Black - Blue - Yellow - Red
Black = left
Blue = ground
Yellow = right
White and red where what I thought would need to be connected to mute the am/fm input. But so far they are 100% not needed in my case.
Well, the aux-in aspect of this little project is DONE! :clap:
The off road lights are hooked up to that switch now too.
I still have to install the sending unit for the oil PSI gauge, but everything else is finished up.
A bit of solder and heat shrink.... With the exception of the lead from the gauge to the sending unit, and the switch to the off road lights, everything used the OEM connectors. I even used the ash tray light pigtail for 12v and ground to the off road light switch :brow:
Gauge turns on at key-on, and you can change the backlight color. I chose it for the green to go with the green digidash.
Off road light switch gets power when clearance lights are turned on.
here are some pics.
And finally...
One more note worth mentioning...
This style head unit that does NOT have a 5-pin DIN pigtail coming out of the back of the head unit is a VERY tight fit once you plug that cable in. I had to massage that cable end pretty good to get it to fit. It was hitting the air box.
I did get it to fit, but it still hits.
The head units with 5-pin DIN pigtails should not have this problem.
  • 10 months later...
  • 7 months later...
  On 11/5/2011 at 6:54 PM, Idasho said:
UPDATE.
It works!
A silly note though.... it seems that the switch is 100% NOT needed. At least on the two head units I have. When I plug my IPhone into the new 3.5mm jack, the radio signal cuts off 90+% there is still a VERY slight signal, but with the IPhone volume up more than 50%, and head unit volume adjusted accordingly, you cannot hear it at all, even when there is no music.
I just installed this, without the switch of course, and am having the same experience. This is great! I love it!!
  • 1 month later...
