woodi9er Posted November 3, 2011 Share Posted November 3, 2011 when I pull on my trunk button nothing happens. I can still open it with my key atleast. I can see the wire right on the latch but no idea how to tighten it or hook it up proper to make the latch work. any suggestions?? It's a 2000 legacy GT. Link to comment Share on other sites More sharing options...
johnceggleston Posted November 3, 2011 Share Posted November 3, 2011 if it is a sedan, usually there is a ''trunk release cancel'' switch / lever on the inside of the trunk latch mechanism. look for it. this will allow or not allow the trunk release lever, by the gas door opener, to open the trunk or not. Link to comment Share on other sites More sharing options...
woodi9er Posted November 3, 2011 Author Share Posted November 3, 2011 thank you i will go check that out right now Link to comment Share on other sites More sharing options...
woodi9er Posted November 4, 2011 Author Share Posted November 4, 2011 well I tried that and no luck. when I pull the lever there is no resistance. something needs tightened it appears??? Link to comment Share on other sites More sharing options...
bheinen74 Posted November 4, 2011 Share Posted November 4, 2011 hard to tighten a broken cable. Link to comment Share on other sites More sharing options...
Durania Posted November 4, 2011 Share Posted November 4, 2011 I can't imagine replacing that cable to be fun. Be glad, my 05 STi doesn't even get a remote trunk release. Link to comment Share on other sites More sharing options...
1982gl4 Posted November 4, 2011 Share Posted November 4, 2011 I can't imagine replacing that cable to be fun.. No it's not. I added one to my last impreza, as it was a brighton and didn't come with one. I had to take the drivers side door sill cover off, the drives seat out, the rear seat out, and flop the carpet to one side. The trunk I just had to move some of the covers out of the way back there. It was doable, just kind of time consuming. Link to comment Share on other sites More sharing options...
bheinen74 Posted November 4, 2011 Share Posted November 4, 2011 if you are lucky, the cable is intact, but maybe one of the hoop ends came off the hook it pulls. Link to comment Share on other sites More sharing options...
