98 forester starting question
sister in law , 98 forester, 190,000mi a/t , when you turn the key it does not always start , but after the 2nd or 3rd time it starts fine, but does not do it all the time, i am thinking maybe coil pack ? , not sure when last tune up was, any comments ? thanks
sounds like the typical problem you would have to use a push button for.
try jumping the wire from the small tab on the starter to the battery to make sure it works.
If you drop the kick panel, you can find the wire to the ignition switch, and get a used ign switch from an ea81-ea82-legacy and just plug it in. If it starts on the first try, then the switch could be going bad.
my 94 legacy does this where i get a click, but no turn, and if i rattle the key a few times, she will catch.
The legacy starter will not fit your forester. You will need a forester starter for an auto trans. There is an MT starter and it is different also. I drive a forester and I know that the starter is specific to the car.
Good Luck
I've purchased alternator and starter parts from this guy:
http://www.ebay.com/itm/Mitsubishi-Starter-Starter-Solenoid-New-/230634151169?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item35b2dddd01
Just email with your Mitsubishi starter part # (M000T84481 or M001T84481)to make sure that this is the right solenoid for you car. If those don't work, you can try to get part numbers from another auto parts site.
Edited by hohieu
clarity
