ubtripn Posted November 9, 2011 Share Posted November 9, 2011 I thought they had temp sensors, is this normal? Link to comment Share on other sites More sharing options...
6 Star Posted November 9, 2011 Share Posted November 9, 2011 The previous owner probably bypassed the temp sensor and wired the fan so that it would stay on as long as the car is on or on "acc". It is a pretty common half-a** fix. Link to comment Share on other sites More sharing options...
zukiru Posted November 9, 2011 Share Posted November 9, 2011 Yah I gotta get a new temp switch for mine. Currently half-azzed myself. Link to comment Share on other sites More sharing options...
ubtripn Posted November 10, 2011 Author Share Posted November 10, 2011 Cool, thanks. Funny thing was that he complained that it takes a little while to warm up! =) Link to comment Share on other sites More sharing options...
Virrdog Posted November 12, 2011 Share Posted November 12, 2011 I think one of the fans will always run if the HVAC is set to A/C. Link to comment Share on other sites More sharing options...
ubtripn Posted November 14, 2011 Author Share Posted November 14, 2011 I didn't know that, thanks. I only have one fan on this 1.8. Is that standard? Link to comment Share on other sites More sharing options...
MilesFox Posted November 14, 2011 Share Posted November 14, 2011 There should be a mechanical fan on the WP pulley. The electric fan does come on with ac, and the relays are located on the firewall behind the strut. the fan is powered by the accessory circuit see if the fan operates with the terminal on the radiator unplugged. IF it does, it would be ac relay related. if not, the thermo switch is stuck closed(on the radiator) if you unplug it, you can make the fan come on by jumping the thermoswitch terminals. you can make a manual switch here at these connectors to override the thermoswitch. Link to comment Share on other sites More sharing options...
ubtripn Posted November 18, 2011 Author Share Posted November 18, 2011 Thank you. I think it may have had ac once because the pulleys have the 2 grooves but now just one belt. There is no mechanical fan, just a full time electric fan. I will send a pick as soon as I can figure out how to. Thanks. Link to comment Share on other sites More sharing options...
