83 brat, 3/2 lift.
if i build a lift for my brat,
does the front strut lift NEED to be the same as the front crossmember lift?
to put it another way,
if i lift the front 3 inches, do i need to drop the crossmember 3 inches?
or can i drop the xmember 2 inches instead, and thus gain an
inch of ground clearance?
someone, not to be named, told me that works?
im not trying to call BS on them. i just want to be 110% certain that is okay??
its alright man it was me whom told ya. only because i have been drivin that way in my brat for quite a few miles. but i am curious to what other people say. hoping things are decided before i get to welding the strut pieces for ya. ill holp off on those till sunday for you,
cheers
Edited by sube101
It is doable.
If the upper strut mounts are pushed INWARD far enough you can do it without any major alignment issues. Just make certain you do not bind the coil springs on the strut towers. Doing this will also effectively narrow the track width of the front tires a bit too. So if you had any inner fender rubbing issues before, it may get worse (unless the lift is great enough to fix that problem)
That said, your CV joints will hate you if you do not drop the subframe with the struts.
this is the basic idea then, yea?
<sorry for stealing your brat pic, mcbrat>.
if you cant find 2.5" tube, maybe you could just combine
2" and 1/2"? i know, im sorry, pain in the backside.
im just real shy on the CV angle situation.
the straighter they sit, the safer i will feel.
i figure, even a HALF inch extra clearance for
my oil pan, etc, will help me out a ton.
also, i have a skid plate, for the LONG style bullbar.
its mild steel, lots of surface rust, and heavier than
a Vespa. it gets the job done, pleeeenty strong. but it is
designed for a stock suspension. i doubt it can even be
FORCED to work for a 3 inch front lift.
how much would it cost to get a nice clean
aluminum plate made? good quality aluminum. maybe...
1/4" thick. with like 8 or 12 small < 1" >
ventholes, and a big 3" drain plug access hole?
is that a possibility? i bet if you went to the trouble of making
one for ME, lots of other guys would be interested also.
Edited by tallwelder81
adding pic
well I. Couldn't find 2.5 but I cut some 3x2 so that it would remain all stock. And it would depend on the demesions of the plate. At the moment our running water jet can only fit 24 x40 sheets our big water jet is currently down. And if there is any bending for the skit plate I couldn't do it. I have I don't have any machines to bend sheet metal or plate yet
