KaraK Posted December 2, 2011 Author Share Posted December 2, 2011 (edited) OK- It is possible I have more than one issue going on... I would have bet that these current noises were coming from the front- axle,suspension,or bearing related- but I am no "mechanical genius"... Just seemed wierd, driving at a steady speed (like 60mph) let off the gas, sound diminished, put on the gas- (not enough to really accelerate) just "put it under load" (if that makes sense) tunk,tunk,tunk sound very pronounced. Problem w/all the non-busy, roads around here, they are all done w/tar and pea gravel- hard to hear anything, but the crunchy gravel sound- but I'll try. For the record, I do need rear brakes. Got the "warped rotor pulse" going on. Which wheel has E-brake? (just one rear right?) Would a bad bearing heat up the wheel? (fronts are not hot) Edited December 2, 2011 by KaraK Link to comment Share on other sites More sharing options...
heartless Posted December 2, 2011 Share Posted December 2, 2011 yes, a bad wheeling bearing will eventually cause the hub to get hot. you say the fronts are not hot, how about the rears?? dragging brakes can also cause the wheels to feel hot take it for a test drive, then check all 4 wheels for excess heat - if you find one that is warmer than the others, that is the one you need to be looking closely at. hmmm, needs rear brakes? umm, mine makes a kind of grindy, thunky noise as it is in need of new pads on the back (have them, just need to get them on ) but with mine the noise is more pronounced at slow speeds - so... Link to comment Share on other sites More sharing options...
KaraK Posted December 3, 2011 Author Share Posted December 3, 2011 Jo- see PM. Went for a drive today, (froze my a** off w/windows open) and think the noise starts around 45-50mph. hard to tell, on these rough roads. Was definately less pronounced, than 60mph on smooth highway. Stuck calipers- been there, done that. I check wheel temps. just about every time I drive. Rears slightly warmer than fronts- but not hot, and nothing drastic. Am curious though, which has E-brake? Really don't think this is the brakes, yes they have issues- but... When I went onto that exit ramp, I was NOT braking at the time. Just seemed wierd, driving at a steady speed (like 60mph) let off the gas, sound diminished, put on the gas- (not enough to really accelerate) just "put it under load" (if that makes sense) tunk,tunk,tunk sound very pronounced. I am still unable to determine if it's engine or wheel speed related-sorry. Link to comment Share on other sites More sharing options...
heartless Posted December 3, 2011 Share Posted December 3, 2011 (edited) KaraK said: ...When I went onto that exit ramp, I was NOT braking at the time. Just seemed wierd, driving at a steady speed (like 60mph) let off the gas, sound diminished, put on the gas- (not enough to really accelerate) just "put it under load" (if that makes sense yes it does) tunk,tunk,tunk sound very pronounced. I am still unable to determine if it's engine or wheel speed related-sorry. ok... not braking at the time...changes with very light load changes...i am beginning to lean toward something with the drivetrain (drive shaft/axle related) which could also be wheel bearings, altho - if you arent getting pronounced heat on one wheel - i kind of dont think it is wheel bearing...possibly U-joints?? oh, and on my car, the e-brake is both front wheels - yours may be different however... Edited December 3, 2011 by heartless Link to comment Share on other sites More sharing options...
KaraK Posted December 4, 2011 Author Share Posted December 4, 2011 E-brake-front wheels???!!!??? Is this true for mine??? (2001 3.0L Outback-Automatic)? Link to comment Share on other sites More sharing options...
CNY_Dave Posted December 4, 2011 Share Posted December 4, 2011 KaraK said: E-brake-front wheels???!!!??? Is this true for mine??? (2001 3.0L Outback-Automatic)? No, yours is in a small drum brake inside the rear rotors. Dave Link to comment Share on other sites More sharing options...
KaraK Posted December 10, 2011 Author Share Posted December 10, 2011 Thanks Dave- Both rears??? Haven't had them apart at all, yet... Anything special I need to be aware of- when I do them? Got the fronts all fingered out. (Thanks to Tom...TheLoyale) All I know is old GM's... Link to comment Share on other sites More sharing options...
KaraK Posted December 10, 2011 Author Share Posted December 10, 2011 Just seemed wierd, driving at a steady speed (like 60mph) let off the gas, sound diminished, put on the gas- (not enough to really accelerate) just "put it under load" (if that makes sense) tunk,tunk,tunk sound very pronounced. OK- I thought this comment^^^would've been a "smoking gun" for all of you that know more than I... But... How's this for another piece of the puzzle... Car pulls to the left upon acceleration... Example...Driving along at 40 MPH. @ 1500 RPMs, step on it, to 2000ish RPMs, car pulls to the left, steering wheel pulls to the right... Does any of this make any sense to anyone??? I am an ignorant F***, ready to take it somewhere, but don't want to be clueless as to the diagnosis... Thanks-K Link to comment Share on other sites More sharing options...
ROOWHO Posted December 10, 2011 Share Posted December 10, 2011 just bring it over I will fix it fer ya Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 10, 2011 Share Posted December 10, 2011 OK - I'm gonna suggest a differential stub has popped out partially and the seal is leaking too. Check the front diff oil level. Get under the car and examine the inner and outer boots and look for diff oil. Link to comment Share on other sites More sharing options...
KaraK Posted December 10, 2011 Author Share Posted December 10, 2011 (edited) AhHa! I think I may know who RooWho Is... Are you Ron??? (A non-Soob car-guy old friend)???? If you hadn't moved to flippin TX. you know I would be there!!! Edited December 10, 2011 by KaraK Link to comment Share on other sites More sharing options...
KaraK Posted December 10, 2011 Author Share Posted December 10, 2011 1 Lucky Texan said: OK - I'm gonna suggest a differential stub has popped out partially and the seal is leaking too. Check the front diff oil level. Get under the car and examine the inner and outer boots and look for diff oil. You know, it feels like something has "popped out" but I checked all fluids/boots a week or 2 ago, boots were dry, fluids OK. As I recall, diff oil was a little overfull when I bought it, and is now (as of 2 weeks ago)... Pardon my ignorance, WTF is a "differential stub"??? I will go check anything right now, if it will help me finger this out... Thanks! Link to comment Share on other sites More sharing options...
KaraK Posted December 10, 2011 Author Share Posted December 10, 2011 ROOWHO should choose to accept private msgs. Link to comment Share on other sites More sharing options...
CNY_Dave Posted December 10, 2011 Share Posted December 10, 2011 KaraK said: Thanks Dave- Both rears??? Haven't had them apart at all, yet... Anything special I need to be aware of- when I do them? Got the fronts all fingered out. (Thanks to Tom...TheLoyale) All I know is old GM's... Yes, both rears. It's much like a GM drum brake inside the rotor. Tough part is de-adjusting the Ebrake and the adjuster enough to get the shoes to clear the rust ridge. Dave Link to comment Share on other sites More sharing options...
heartless Posted December 10, 2011 Share Posted December 10, 2011 KaraK said: ROOWHO should choose to accept private msgs. ROOWHO cant - one must have 10 posts minimum to have pm priveleges sorry I'm not much more help right now... Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 10, 2011 Share Posted December 10, 2011 (edited) KaraK said: You know, it feels like something has "popped out" but I checked all fluids/boots a week or 2 ago, boots were dry, fluids OK. As I recall, diff oil was a little overfull when I bought it, and is now (as of 2 weeks ago)... Pardon my ignorance, WTF is a "differential stub"??? I will go check anything right now, if it will help me finger this out... Thanks! I think your car is built like my wife's which has splined stubs sticking out from the front diff. The big axle cups are splined internally and slip over the stubs and are held in place by a spring pin. However, the stubs are held into the diff by a 'circlip' (w'ever) a circle of springwire in a groove. (IIRC) Some of your initial symptoms seem to fit a scenario in which a 'hard' turn (to the lock) could have pulled on the stub enough to pop it loose - enough to compromise the diff seal - cause leakage of the fluid (which might blow back onto the exhaust) and maybe cause the smell (diff oil smells bad anyway - so it may smell different than engine oil if it got on hot exhaust) thuinking and other odd driveline sensations you report. Doesn't mean any of that is correct, but it's something different to look for. (could be the previous owner got an axle that was too short - or, the stub was pulled out of it's groove just slightly when the old axle was pulled out, but your hard turn when reversing pulled it more, comprimised the seal, it bound-up and is now so far out of place is intermittently engaging internally) Edited December 10, 2011 by 1 Lucky Texan 1 Link to comment Share on other sites More sharing options...
KaraK Posted December 12, 2011 Author Share Posted December 12, 2011 Thank You to "I Lucky Texan"!! What car does your Wife drive? Stuff you say makes sense to me... (Correct or not) All of this started when Spouse used the car for pizza deliveries... (Of course... all was fine...) I cannot say what may have occured... Does this diagnosis depend on a visible leak of gear lube? I will continue to monitor levels- but see no "visual evidence" at this time... I do know, that both front CV axles are Napa aftermarket replacements, which no-one on here likes... Link to comment Share on other sites More sharing options...
bheinen74 Posted December 12, 2011 Share Posted December 12, 2011 Napa axles suck on a Subaru. May I ask why you went with napa axle, since they suck out the box when new even, I cannot drive a car with them for many miles before I toss them, and toss them far in the trash. wow. good luck, Link to comment Share on other sites More sharing options...
KaraK Posted December 12, 2011 Author Share Posted December 12, 2011 Yes, You may ask... The previous owner installed them in Oct.2009 w/103,827 miles on the clock... He was a traveling salesman- they were installed in Alabama... He and I, both live in Wisconsin- within 20 miles of each other... I know enough to research my purchases-(care about my car) apparently he did not... Link to comment Share on other sites More sharing options...
heartless Posted December 12, 2011 Share Posted December 12, 2011 hmmm - 2 year old Napa axles??? could very well be the problem... Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 12, 2011 Share Posted December 12, 2011 (edited) KaraK said: Thank You to "I Lucky Texan"!! What car does your Wife drive? Stuff you say makes sense to me... (Correct or not) All of this started when Spouse used the car for pizza deliveries... (Of course... all was fine...) I cannot say what may have occured... Does this diagnosis depend on a visible leak of gear lube? I will continue to monitor levels- but see no "visual evidence" at this time... I do know, that both front CV axles are Napa aftermarket replacements, which no-one on here likes... Yeah, sry, my wife drives an 03 H6 Outback wagon. I recently did some work on it and one repair was an axle replacement due to split inner boot. My car is an 06 WRX wagon. If the smell comes and goes, it might mean that sometimes the seal on the front diff is leaking and sometimes not. If possible, lift he front of the car, secure on jacks, and turn the wheel all the way left, then check the left inner axle joint. the (probably green) 'cup' part should stay in the same position and not shift in-out more than , maybe, a 2-3 mm. maybe someone else here can confirm that. Then, check the right side after turning the wheel all the way to the right. I should also mention that, it's possible grease could be pushed out either end of a rubber boot. Particularly on a rebuilt axle. If it was over-greased or the bands are not tight, etc. That also might happen during or after extreme turning of the wheels when the boots are stretched/compressed a lot. They wouldn't have to be split to deposit some grease onto the exhaust. The 'split boot problem' just happens frequently because the inner boots are exposed to so much heat from the exhaust pipe. Edited December 23, 2011 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
KaraK Posted December 23, 2011 Author Share Posted December 23, 2011 Thank You again, to "1 Lucky Texan"- I wasn't able to get back on here for a while...(wow it looks different) I haven't -smelled the smell- since "the spouse" used my car to deliver pizzas. The other symptoms are getting worse/more noticable though...I'm hearing the tunk tunking at lower speeds, and I now feel pulling at every shift (change of RPM). I haven't been under the car for a week or two- but, didn't see any residue that would have led me to a clue as to leakage... Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 23, 2011 Share Posted December 23, 2011 KaraK said: Thank You again, to "1 Lucky Texan"- I wasn't able to get back on here for a while...(wow it looks different) I haven't -smelled the smell- since "the spouse" used my car to deliver pizzas. The other symptoms are getting worse/more noticable though...I'm hearing the tunk tunking at lower speeds, and I now feel pulling at every shift (change of RPM). I haven't been under the car for a week or two- but, didn't see any residue that would have led me to a clue as to leakage... Check the level in the front diff - the stick on the other side from the transmission dipstick. It's short, down low, and often covered in 'muck'. Link to comment Share on other sites More sharing options...
KaraK Posted January 10, 2012 Author Share Posted January 10, 2012 Still dealing with this issue... I have a new idea... engine mounts... Anyone have an opinion on this??? If this is my problem... good places to purchase them??? Do they need to be new? or is used OK? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 10, 2012 Share Posted January 10, 2012 hmmm....have you inspected the ball joints? If they are severely worn, folks report sounds and weird 'pulling'. But from what I've read, there's usually some odd 'drifting' or pulling when you brake too. But it may depend on how worn they are. good luck Link to comment Share on other sites More sharing options...
