mm88swrt Posted November 13, 2011 Share Posted November 13, 2011 i'm wondering what the timing procedure is for an er27. i know it's basically an ea82, but i'm assuming the timing procedure might be different. problem is i'm in alaska, and the person who is working on the car is in oregon and has no experience with the motor. was wondering if anyone has step by step instructions on how to install the timing belts and ditsy. any help would be amazing!!! i just want the suspension for my gl-10! Link to comment Share on other sites More sharing options...
mm88swrt Posted November 13, 2011 Author Share Posted November 13, 2011 is the timing procedure the same as the ea82's? or does it differ? Link to comment Share on other sites More sharing options...
zukiru Posted November 13, 2011 Share Posted November 13, 2011 (edited) The difference is the tensioners. Requires a tool/workaround to hold one of them slack. Otherwise it's the same. Can't Recall the specifics at this moment. Edited November 13, 2011 by zukiru Link to comment Share on other sites More sharing options...
MilesFox Posted November 13, 2011 Share Posted November 13, 2011 The crank rotations, cam timing, and disty timing is same as ea82. The tensioner, however, is different. You have to turn a slot on the bottom to install the belt. The only thing different is firing order being 6 cylinders. The front 4 cylinders rotate the same as ea82. As long as you know #1 on the cap. search the internet for 'subaru maintenance' or ea82 timing belt' and you will find helpful videos. Link to comment Share on other sites More sharing options...
mm88swrt Posted November 13, 2011 Author Share Posted November 13, 2011 i know you line up the center of the 3 notches, and driver cam up ^. and install driver belt. then 360 clockwise to center notch, passenger cam up ^. then install passenger belt and to zero to install ditsy. if i recall correctly? Link to comment Share on other sites More sharing options...
MilesFox Posted November 13, 2011 Share Posted November 13, 2011 after you install the 2nd belt, rotate the crank once more to bring the operation back to step one. From there, rotate to the 0 mark and drop in the disty. There are two whole 360 deg crank rotations for the whole procedure Link to comment Share on other sites More sharing options...
mm88swrt Posted November 13, 2011 Author Share Posted November 13, 2011 thanks for the quick response guys!! it helped a ton!!! workin on cars over the phone is a tough job but we got her dialed. now i can get back to my oregon stanford game!!!! go ducks Link to comment Share on other sites More sharing options...
