EJ Swap wiring trimdown 98 Legacy
Scott in Bellingham
I have a 98 Legacy wagon 5 speed wiring harness Im in the process of thinning it out for a EJ2.2 swap into a EA car, I have the 98 Impreza RS Servicve manual and wanted to know if the pinouts and engine wiring would be the same or if not where could I get the correct wiring diagrams and pinouts for this harness ;):-p:Flame::o also anything I should be aware of as this is my first , I have chux write up and also have a EJ in one of my EA cars but I didnt wire it
  GeneralDisorder said:
Why didn't you save the fuel pump and ignition relay's? It's easier to just wire power to them and then route the fuel pump power wire to the fuel pump via the existing rear harness.
OK sounds good maybe on the next one, like I said this is the only one Ive done, what you say makes sense
You can also leave all the dealer diagnostic connectors - just in case you get the opportunity to use the Subaru Select Monitor, etc.
Looks to be OBD II, and I think I see the OBD II port. Make sure the red/black wire(s?) to it has 12v Batt+.
Although, if the IG. relay is gone, may need to check that all item supposed to be powered actually get power when you wire it up. the big yellow wire (Batt+)in particular feeds power to lots of stuff before it goes to the relay, so things like the Transistor, IAC, Vent solenoid, etc... may not be in the loop still.
