Gary Greenspoon Posted November 14, 2011 Share Posted November 14, 2011 I'm new to forum; this my first post. I have a 1994 Loyale, I have 160K km on car. PROBLEM: 4WD does not now activate: Though rarely needed, I'd engage 4WD from time to time both to test and activate its parts. I just tried it multiple times and there is no indication on dash, and no mechanical sound, so it leads me to think there is no power. Fuse panel shows one fuse as "Back turn (4WD-AT)" and the fuse is good. Any suggestions? Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 14, 2011 Share Posted November 14, 2011 (edited) Welcome!if you're Not Sure if 4WD isn't Working, you can do some tests. in example: Try to Accelerate in a Muddy / Snowy \ loose Terrain while someone else Looks at the Tires for Spin. The vacuum accumulator bottle, under the windshield, behind the passenger's strut tower (on LHD Models) at the Engine Bay, provides vacuum for the A/C Buttons on the Dashboard, plus for the 4WD engagement on the Push-Button transmission models, check the vacuum lines around it.Kind Regards. ►Edited to fix the Yellow Text. Edited July 6, 2014 by Loyale 2.7 Turbo Link to comment Share on other sites More sharing options...
MilesFox Posted November 14, 2011 Share Posted November 14, 2011 vacuum solenoid operation with a dual post dual throw switch on the shifter. there is a bank of solenoids on the driver firewall. one is on and one is off, alternately to allow vacuum to pull one way or the other on the 4wd mechanism. if your heater fan is only blowing out of the dash vents, then look for a loose vac hose between the canister and the passenger intake, as that hose is easy to knock loose and miss. If so, that is your problem. You can manually manipulate the 4wd diaphragm linkages to get into 4wd. if the solenoids are not working, you can swap the vac hoses to engage or disengage the 4wd, provided the vacuum system is intact. if you need to replae the solanoids, you can grab one from any other soob with a pushbutton 5spd (gl, gl-10, loyale, dl), or locking diffl(xt, rx) Link to comment Share on other sites More sharing options...
SubaruJawn Posted November 17, 2011 Share Posted November 17, 2011 i'd check the vacuum like miles sais, i had the same issue with my loyale years ago, sure enough i forgot to connect the vacuum line. Link to comment Share on other sites More sharing options...
TheLoyale Posted November 18, 2011 Share Posted November 18, 2011 (edited) A new Vacuum solenoid from the dealer is only $50. I bought a new one some time back due to the Diaphragm failing and allowing ATF to enter the intake. Seeing as you're in Canada or Australia, I dunno how close your local deal is? Edited November 18, 2011 by TheLoyale Link to comment Share on other sites More sharing options...
raoulduke4247 Posted August 2, 2012 Share Posted August 2, 2012 I just had this same problem. I went to Jiffy Lube to get my oil changed before a road trip. When I got to my destination my 4wd would not work. I did notice on the way that the heater was only blowing out the vents. I figure that when they were taking the air filter out to check it that they knocked the hose loose. Link to comment Share on other sites More sharing options...
ivans imports Posted August 2, 2012 Share Posted August 2, 2012 hose on ps side of intake that gos to vacume storage pot 1 Link to comment Share on other sites More sharing options...
Gloyale Posted August 2, 2012 Share Posted August 2, 2012 When you replaced the clutch cable, you pulled the vacuum line apart where it comes into the cab, in the upper corner of the dash, above the clutch pedal. Look around up there for a black, skinny hard vacline, and a rubber line to connect it to. Your dash vents will start switching again too. Link to comment Share on other sites More sharing options...
pacgas Posted July 6, 2014 Share Posted July 6, 2014 Your statement of ONLY the dash vents operating is a great lead. Looked at intake manifold vacuum line leading to vac. Canister and sure enough even though the line was connected, I tugged on it ever so lightly and it fell off. Secured that line and now my 4 wd is operating and so is my defrost vent. Link to comment Share on other sites More sharing options...
Rust Posted July 7, 2014 Share Posted July 7, 2014 I ended up just drilling a hole in the trans tunnel and installing my own 4WD manual switch made from an old towel rack steel bar. No more fiddling w/ canisters and cables. Link to comment Share on other sites More sharing options...
Houston505 Posted July 24, 2014 Share Posted July 24, 2014 Just went through the same thing. I unhooked the vacuum lines when I was changing the fuel filter and hoses, forgot to hook 'em back up. Link to comment Share on other sites More sharing options...
Gloyale Posted July 25, 2014 Share Posted July 25, 2014 On 7/7/2014 at 1:01 PM, Rust said: I ended up just drilling a hole in the trans tunnel and installing my own 4WD manual switch made from an old towel rack steel bar. No more fiddling w/ canisters and cables. Yeah...now you just deal with road noise, dust, and water/mud comin up through the hole in the floor. Canister and cables work just fine and are pretty damn simple..... I guess some people just fix everything with a big stick. Link to comment Share on other sites More sharing options...
