direwolf Posted November 21, 2011 Share Posted November 21, 2011 So my 85 GL has taken up the habit of letting out a horrible Sheek-sheek-sheek that seems to be eminating from the front right wheel - the frequency corresponds to the car's velocity, not the engine's revs. It's that distinct gut-wrenching sound of metal scraping metal. I thought that perhaps the front disc was warped, but that does not seem to be the culprit. Any ideas what might be going on here? If it's not obvious from my post, I am very new to understanding cars, how they work, and how to fix them, so any help or suggestions would be tremendously appreciated. Thanks everyone. Link to comment Share on other sites More sharing options...
zukiru Posted November 21, 2011 Share Posted November 21, 2011 wheel bearing is my first guess. I did them myself but I have a fair bit of wrenching experience. you can land a used hub from a junkyard which will be easier to install. welcome to USMB. Link to comment Share on other sites More sharing options...
The FNG Posted November 21, 2011 Share Posted November 21, 2011 I would recommend getting your wheel bearings looked at. Does it happen while you are turning or just driving in general? I'm not sure on your wrenching experience, but they are relatively easy and cheep to replace yourself. I would say 3-4 hours and less than $50 in bearings, grease and seals plus a jack, wrenches, latex gloves and some rags. http://www.ultimatesubaru.org/forum/showthread.php?t=77491 check out this post and you will be able to see what it takes. Good luck. Or like zukiru said, pull a used hub from a junk yard with bearings already in it, but then it is a guess if they are still good. Link to comment Share on other sites More sharing options...
MilesFox Posted November 21, 2011 Share Posted November 21, 2011 bad wheel bearings, when bad enough, will cause the outer edge of the rotor to drag along the caliper bracket. look for wear pon the edge of the rotor. Link to comment Share on other sites More sharing options...
direwolf Posted November 21, 2011 Author Share Posted November 21, 2011 Thanks, folks. Wheel bearings. Larry Owens and I will have to take a look... Link to comment Share on other sites More sharing options...
