opus Posted November 24, 2011 Share Posted November 24, 2011 The drivers side belt wants to work its way backward, toward the engine block, any ideas? It will start to shave itself thin. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 24, 2011 Share Posted November 24, 2011 Misaligned pulleys? ... maybe it has a Loose (tensioner) pulley. Link to comment Share on other sites More sharing options...
man on the moon Posted November 25, 2011 Share Posted November 25, 2011 Perhaps the cam is loose? Try tightening down all three screws holding it down (10mm) and the tensioner as was mentioned (12mm). Link to comment Share on other sites More sharing options...
man on the moon Posted November 25, 2011 Share Posted November 25, 2011 cam pulley* Link to comment Share on other sites More sharing options...
MilesFox Posted November 25, 2011 Share Posted November 25, 2011 maybe the crank sprockets are backwards or in the wrong order. they will fit either way, but are supposed to fit one way. The lip on the inner is a little different than the outer one. the one with the rollpin(if present) should be on the outside behind the crank pulley Link to comment Share on other sites More sharing options...
opus Posted November 25, 2011 Author Share Posted November 25, 2011 maybe the crank sprockets are backwards or in the wrong order. they will fit either way, but are supposed to fit one way. The lip on the inner is a little different than the outer one. the one with the rollpin(if present) should be on the outside behind the crank pulley I'm thinking it might be this. Peeking in there, I dont see that little lip that should be on the block side. I think thats whats doing it. I need to find a pic to see what it supposed to look like, to be sure. Link to comment Share on other sites More sharing options...
