belezeebub Posted November 25, 2011 Share Posted November 25, 2011 Okay the yahoo that replaced the Dash in my Sons Brat swapped out and Jury rigged the heater/ac/defrost system from what ever the doner car was I produce more heat out my rear end after eating chili then this thing does any ideas? it looks like all the flaps are moving the air is being redirected but its cold, driving in winter you need a ski coat mittens and snow boots to ride in this thing. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 26, 2011 Share Posted November 26, 2011 Is the core clogged? There's a control valve under the dash that shunts the hot water back into the return line instead of pushing it through the core - depending on the position of the hot/cold lever. I would take both hoses loose from the core in the engine bay and insure that you have flow - and then insure than the control valve is operating and not clogged or something. GD Quote Link to comment Share on other sites More sharing options...
Turbone Posted November 26, 2011 Share Posted November 26, 2011 Also make sure if the core is even getting hot water. Both hoses thru the firewall from engine to the core hooked up? Quote Link to comment Share on other sites More sharing options...
whistler Posted November 26, 2011 Share Posted November 26, 2011 Also possibly an aftermarket t-stat? I believe that's a part that people still recommend getting from the dealer? I know there's at least 3 different temperature options that are listed by parts stores for my '85 and two of them open earlier than OE. My brat is a lot warmer with the correct temperature t-stat in it. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 26, 2011 Share Posted November 26, 2011 Yes a Subaru OEM thermostat is always a good idea. Good call Tom. GD Quote Link to comment Share on other sites More sharing options...
