trucking45 Posted November 26, 2011 Share Posted November 26, 2011 Okay i got a weber carb with the main barrel number stamped as 27 and the second one stamped as 26 what would be the best amount of turns for the mixture screw Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 26, 2011 Share Posted November 26, 2011 You don't count turns - you adjust till the engine runs correctly - either by ear or with a wide-band O2 sensor. Start it at 3 turns out from seated - then adjust your idle speed and mixture (once warmed up) till they are where you want. Get the idle speed down to about 800 and then adjust the mixture to lean-best idle. That is about 1/4 turn out from where the engine starts to stumble and change pitch when you are screwing the mixture screw in. GD Link to comment Share on other sites More sharing options...
trucking45 Posted November 26, 2011 Author Share Posted November 26, 2011 alright thanks....any ideas as to way the choke could be sticking to? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 26, 2011 Share Posted November 26, 2011 trucking45 said: alright thanks....any ideas as to way the choke could be sticking to? I would have to see it. Probably the linkage is binding and needs to be adjusted (bent). GD Link to comment Share on other sites More sharing options...
trucking45 Posted November 26, 2011 Author Share Posted November 26, 2011 i could post pics tomorrow (if i remeber) Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 26, 2011 Share Posted November 26, 2011 Sorry - I meant I would have to see it in person. You should pull the e-clip that connects the choke plate shaft to the linkage and see if it's the linkage or the shaft, or misadjusted plates, etc. GD Link to comment Share on other sites More sharing options...
trucking45 Posted November 26, 2011 Author Share Posted November 26, 2011 oh okay i can take a look at it on sunday when i do my first oil change since i had my brat Link to comment Share on other sites More sharing options...
trucking45 Posted December 8, 2011 Author Share Posted December 8, 2011 HELP!!!... My 81 brat barely made it home it was sputtering and coughing and i had to restart it twice and keep it above 1500 rpms for it to run i need help quick Link to comment Share on other sites More sharing options...
Redcap Posted December 8, 2011 Share Posted December 8, 2011 trucking45 said: HELP!!!... My 81 brat barely made it home it was sputtering and coughing and i had to restart it twice and keep it above 1500 rpms for it to run i need help quick Did you play with the mix screw more? Link to comment Share on other sites More sharing options...
trucking45 Posted December 8, 2011 Author Share Posted December 8, 2011 ya i had it running good no issues with it then out of no where it just starts cutting out then sputtering like it's not getting any fuel but it's getting fuel my fuel pump isn't dieing so idk whats up with it Link to comment Share on other sites More sharing options...
opus Posted December 8, 2011 Share Posted December 8, 2011 Is the choke closed? Link to comment Share on other sites More sharing options...
trucking45 Posted December 8, 2011 Author Share Posted December 8, 2011 i don't think so..but it's not the first time it's done this it's just the first time it was this bad Link to comment Share on other sites More sharing options...
