Weber carb on a 81 brat
You don't count turns - you adjust till the engine runs correctly - either by ear or with a wide-band O2 sensor.
Start it at 3 turns out from seated - then adjust your idle speed and mixture (once warmed up) till they are where you want. Get the idle speed down to about 800 and then adjust the mixture to lean-best idle. That is about 1/4 turn out from where the engine starts to stumble and change pitch when you are screwing the mixture screw in.
  • 2 weeks later...
