How to check HG leakage???
I know,I know.....Stupid question........
Thinking about buying a 85 Brat and I'm looking for all the Advice on how to check for HG leak/damage.
The only method I know is to check what Is coming out of the Tail Pipe, Look for White Smoke,Right????? While reving up the Engine????
I've worked around cars but nothing like a Engine Overhaul or Tranny Overhaul......I guess I've been Lucky:-p
THANKS GUYS, YOU ALL KISS rump roast!!!!!!!!:headbang:
If there's reason to suspect the HGs, you have a few simple checks and a few not so simple.
Simple:
Oil in the coolant/coolant in the oil
Milky "blowby" residue on the oil fill cap. This can also be piston blowby though.(Neither are good)
Bubbles in the coolant res while the engine is running.
Steam pouring out the exhaust.
Less simple:
Compression test, only really counts if the HGs are really bad.
Shop needed:
Sniff test the radiator for hydrocarbons.
I didn't know the obvious signs of a Blown HG but,now I know what to look for. Thank you all.
Also, what does it mean when a Old Subie(EA81) back fires?? I was looking at a 86 GL Hatchback a while ago and it had this problem.....So, I walked away from the deal.....fearing that it would be a costly repair. Thanks again.
Edited by LoveTheeSubie
