My 95 legacy 2.2 has a random no start issue...no real pattern..will start fine,the when you go to start it again,no go...turns over fine.Figuring fuel or ignition problem.Car runs fine otherwise.This was a problem from the previous owner,so i don't have allot of history..any thoughts on where to start?
Also,i have the hill holder unhooked.Is there any adjustments that need to be made so the brakes dont drag? In other words does the HH need to be hooked up? thanks.
I had this exact problem with a 2.2 swap I did a few years ago.
He tried both sensors (cam and crank) with used ones I had and I believe he did cam first and after crank no more problems.
Crank sensors can be hard to remove here in the rust belt though.
