mtnpat Posted November 28, 2011 Share Posted November 28, 2011 Can't figure out how to undo the fuel disconnect on my 07 Outback. Which part am I squeezing, pushing, pulling, etc? I assume the yellow plastic part. I have tried squeezing with the tool below but it did nothing. Will this cheap rump roast tool do the job? Thanks -mtnpat Link to comment Share on other sites More sharing options...
mtnpat Posted November 29, 2011 Author Share Posted November 29, 2011 Never mind I got it. I was able to remove it with this tool and pressing on the inside of the yellow plastic part of the quick disconnect. Not sure how you would be able to get it with a metal disconnect tool, this because you have to get over and past the first ridge in the fuel line to push in on the plastic part and release the connector from the second ridge. With the plastic tool, I was able to force it into the connector and get it to come apart. -mtnpat Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 29, 2011 Share Posted November 29, 2011 Anytime I've done that type with the plastic sleeve I just push the sleeve with my fingers and pull the line. The ones with the round metal spring inside are the type that you have to use the metal disconnect tool on. Link to comment Share on other sites More sharing options...
bru73 Posted November 30, 2011 Share Posted November 30, 2011 too small picks work the best Link to comment Share on other sites More sharing options...
porcupine73 Posted November 30, 2011 Share Posted November 30, 2011 Glad you got it off! What was wrong with the simple hoses and hose barbs/nipples they used to use? Those things were dead easy to work on without any special tools. Did they have too many failures or something? These 'fancy' connectors seem like they would cost more during manufacture. Link to comment Share on other sites More sharing options...
MilesFox Posted November 30, 2011 Share Posted November 30, 2011 I tried to do this with a ford explorer fuel filter under the car. I got the plastic insert tool, but i ended up breaking the fitting so i gave up the whole operation and just left it be. Subarus are more cooperative:) Link to comment Share on other sites More sharing options...
Mike104 Posted November 30, 2011 Share Posted November 30, 2011 MilesFox said: I tried to do this with a ford explorer fuel filter under the car. I got the plastic insert tool, but i ended up breaking the fitting so i gave up the whole operation and just left it be. Subarus are more cooperative:) I did this on my 2004 Ford Exploder and it was a real PITA. It is a two step operation a plastic latch clip and then you need the special tool. Took an hour to change a fuel filter! I guess the higher pressures of fuel injected systems are why they went this way although my '99 Subaru has fuel injection and the hose clamps work ok. Link to comment Share on other sites More sharing options...
MilesFox Posted November 30, 2011 Share Posted November 30, 2011 They made it this way so you go to the dealer instead of doing it yourself. It is intentioanl to make something easy to do yourself impossible without dealer specific tools, to sell you on service after they sell you the car. Link to comment Share on other sites More sharing options...
987687 Posted December 1, 2011 Share Posted December 1, 2011 MilesFox said: They made it this way so you go to the dealer instead of doing it yourself. It is intentioanl to make something easy to do yourself impossible without dealer specific tools, to sell you on service after they sell you the car. This is why I refuse to own anything besides old cars... Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 1, 2011 Share Posted December 1, 2011 Mike104 said: I did this on my 2004 Ford Exploder and it was a real PITA. It is a two step operation a plastic latch clip and then you need the special tool. Took an hour to change a fuel filter! I guess the higher pressures of fuel injected systems are why they went this way although my '99 Subaru has fuel injection and the hose clamps work ok. I changed the filter on my 02 Lincoln LS, which is behind the splash shield on the left front fender, it took longer to remove the wheel and access cover in the splash shield than it did to change the filter. It has these plastic 2 prong "fork" clips stuck in each end. Pry the forks out and the lines pull right out of the filter. 10 minutes, done. Changing the filter in my neighbors Escort, took an hour because the stupid "quick release" clips were gummed up full of crud and dirt, and the thing was buried under the back of the engine between the steering rack and brake booster on the firewall. Amazing how the same company can make that so easy for one car, yet nearly impossible in another. Link to comment Share on other sites More sharing options...
