86subaru Posted March 16, 2004 Share Posted March 16, 2004 ok got another subaru , dl fwd manual wagon, 219,000 mi 88 spfi , the shifter seems real sloppy the clutch is good , any ideals on what the problem may be ? or bad tranny ? can it be fixed easy ? , thanks Link to comment Share on other sites More sharing options...
mdjdc Posted March 16, 2004 Share Posted March 16, 2004 Your problem is in the shift linkage. There are several bushings in the linkage and when they wear out the shifter gets very sloppy. Inspect the linkage from underneath the car and replace the necessary bushings. I have a friend that replaced the subaru bushings with nylon ones from a hardware store. Worked great for him. I relpaced mine with stock components and the slop is all gone. Good luck Link to comment Share on other sites More sharing options...
86subaru Posted March 17, 2004 Author Share Posted March 17, 2004 ok thanks Link to comment Share on other sites More sharing options...
CIS Subaru Posted March 17, 2004 Share Posted March 17, 2004 Jim, can you lift the shifter vertically? If so, your problem is likely that the rubber block that attaches the linkage assy. to the body has separated. I've had this happen on a few of my 2wds. Link to comment Share on other sites More sharing options...
Fuji Fellow Posted March 19, 2004 Share Posted March 19, 2004 MDJDC, You spoke of worn bushings in the shifter linkage. Could you possibly post any pics of just where these are, and what they look like? Thanks, James Link to comment Share on other sites More sharing options...
subiemech85 Posted March 20, 2004 Share Posted March 20, 2004 and thought my driveshaft was going bad, and I discovered that I could reproduce the ping by tapping on the shifter, and make it go away by pulling up on the 4x selector Link to comment Share on other sites More sharing options...
subiemech85 Posted March 20, 2004 Share Posted March 20, 2004 put a wood block in the spot, has lasted more than 2 weeks, fits good and have no plans of putting anything else in there, not even a screw to hold the block in Link to comment Share on other sites More sharing options...
