BOSS 2" EA82 Lift Kits- $100!!!
2" OFF ROAD SUSPENSION LIFT KITS for EA82 cars
This is a bulletproof (literaly, I've tested it :brow:) 2" lift kit for Gen 3 (GL, DL, Loyale, etc.) wagons, coupes, and sedans. It installs in as little as 1 hour if you know what you are doing.
It will put extreme angles on you CV axles, so make sure you have good motor and transmission mounts and spare axles just in case. Camber will be very close to stock so you shouldn't see much different tire wear.
Go from stock:
To Ready to Rock:
Available in Safety Orange Gloss, Olive Green Flat, or unpainted bare steel. Comes with Grade 8 mounting hardware.
Outrageously priced at only $100 per kit!!!!! (plus shipping)
PM me or call me, Bill, at (509) 391-5903. Thanks!
-Bill
its about time i see a 2" lift w/o tabs in the back. mine slip on the pass side from time to time. it messes up my strut top. (i have a homebuilt lift, go figure). so.... how much for just some rears? is this price sticking around or just a special? i could prolly buy a whole kit when the man gives me back my taxes.
RV
RV
This is the every day amazing low price :brow:
I could do just the rears for $50
-Bill
  • 2 weeks later...
  • 3 weeks later...
  • 4 weeks later...
Do you build 2 inch ea81 lifts?
My experience with suspension lifts on EA81s has not been good. The shorter axles in them are already at a sharper angle stock than in an EA82, and typically with a 2" lift the axles blow apart in fairly short order. You'd have to do a full lift with body blocks and all that.
-Bill
Ok thanks for the response. Just trying to make a little room for the 27s I put on my brat. LOL
you can't clear a 27" on a gen2 BRAT without a 4" lift.
You might as well cut away, cause a 2" still wont clear.
Or get a shorter tire. but you would need a 4" lift to clear a 27" with no cutting.
Edited by bheinen74
  • 1 month later...
This topic is now closed to further replies.
