The Scooby Posted March 16, 2004 Share Posted March 16, 2004 ok i had a few kill switches on my camaro, and other cars. well i am now wanting to put one on my wagons. its going to be a momentary switch that you much push to be able to get power to the starter. so it would be: ignition tumbler--------switch---------starter so it would interupt the power from the key to the starter. so that you must press in and hold the button to get the car to start. now, can someone please tell me where the ignition wire is that i am talking about, where it is easist to locate, and what color it you be on my 86 GL wagon. Thanks, Shean also pictures would be helpful. Thanks Link to comment Share on other sites More sharing options...
The Scooby Posted March 16, 2004 Author Share Posted March 16, 2004 oh and also i was wondering, does my carbed 86 GL wagon, 5sp have a electric fuel pump or mechanical, and also where is the power or ground wire for it on the car, im also runnin a kill for fuel if i can. Link to comment Share on other sites More sharing options...
scubaroo Posted March 16, 2004 Share Posted March 16, 2004 :wave: contact superrallyroo:burnout: Link to comment Share on other sites More sharing options...
Supaglu Posted March 16, 2004 Share Posted March 16, 2004 Under the steering column find the wiring harness that goes to the igntion lock, it may have 4 or 6 wires. Trace the "starter" wire (black & white I think) cut this and take both ends to a new 4 pin relay - pins 30 and 87 (the end that comes from the switch put to pin 30) Loop a connection from pin 30 onto pin 86. Take the connection from pin 85 to your choice of switch and the other connection of the switch to a good earth point. When the switch is "on" then your ignition key will work as normal, when off the key will be dead. Another way I have done it is not to use a switch but use the wiring on the back of for example your rear heated window switch, find a wire on the rear of the hrw that is earthed when pushed in and off when released - hence when you leave your car unattended if you leave the hrw switch pushed in then your starter cannot be turned from the igniton switch. DaveH Link to comment Share on other sites More sharing options...
The Scooby Posted March 16, 2004 Author Share Posted March 16, 2004 dave, i was thinking of doing what you are saying, but without a relay, what is the purpose of a relay, when i did it on my other cars i just hard wired in a switch, nothing else. Thanks, Shean Link to comment Share on other sites More sharing options...
Supaglu Posted March 16, 2004 Share Posted March 16, 2004 Shean, If you use a relay it allows you to use a lightweight switch cos all its doing is switching a relay on and off. Are you thinking along the lines of having to push a button whilst cranking - if so then the button would have to reasonably near and may therefore be easy to find. With a relay you can put the switch anywhere you like. DaveH Link to comment Share on other sites More sharing options...
The Scooby Posted March 16, 2004 Author Share Posted March 16, 2004 ya its a push type from wal-mart for a push start. then like you say, i will have to get a relay, can someone please for the radio shack's web site and send me a link to the relay i need. thanks, or atleast the part number for radio shack. Link to comment Share on other sites More sharing options...
The Scooby Posted March 17, 2004 Author Share Posted March 17, 2004 anyone?? Link to comment Share on other sites More sharing options...
78TurboBrat Posted March 17, 2004 Share Posted March 17, 2004 pop the hood of your favorite FORD and bingo, you should have plenty of relays to choose from the part number to one is Bosch 12077864 but the ac relay, light relay, and many others are usable. Link to comment Share on other sites More sharing options...
eyesore Posted March 17, 2004 Share Posted March 17, 2004 I'm using a Wal-mart pushbutton type switch on my '78.... I'm running from an "ignition on" hot wire to the wire on the starter solenoid with a fusable link in the system. Works great. I also have my fuel pump hooked up to a toggle. Nothing is hidden, but it's a complicated enough process (Turn key on, flip fuel switch, push starter button) that no one can start it without directions. Another option for a hidden kill switch is: Is your car an auto?*edit: I see it's a 5spd, but for referance...* If so, splice into the wire from the trans that tells the car it's in park. (this is basically a ground, I think ) Then hide the switch. Until you complete the connection via the switch, the car thinks it's not in park, and won't start. Link to comment Share on other sites More sharing options...
The Scooby Posted March 17, 2004 Author Share Posted March 17, 2004 ok so i could just cus the wire going form the tumbler to the starter, wire in my switch with a fuesable link inthere also and it would be OK? also does my 86 GL carbed wagon have a electric fuel pump, and if it does where does the wiring for the pump run, i want to put a switch on that also. Thanks, Shean Link to comment Share on other sites More sharing options...
mr.radon Posted March 17, 2004 Share Posted March 17, 2004 I have the ultimate kill switch. I work of Kenworth as a electrical and power train engineer. I ran a project where we installed LVD's (Low Voltage Disconnects) into our trucks. They disconnect non-vital battery loads when the trucks is off. Example: coffee maker, dome lights, fridge, acc outlets. This way the truck can start in the morning if the guy falls asleep watching a movie. I hooked one up to my car's main cab feed (not starter, too high a current current). I rewired the head lights so they are always on now. I reset the LVD for 12.5 volts. After three mintuets the LVD shuts off the power to the entire car. I ran a seprate circuit to provide power to a momentary reset switch in the dash. It's made to look like a fog lamp switch. You have to hold this momentary switch down for 10 seconds to reset the LVD. Afterwhich you have three minutes to start your car, if not you have to reset the switch again. With the key in the IGN position, the LVD is over-ridden and can't turn off loads. The same circuit I use to override the LVD I ran to my sterio and clock, so the LVD would not disconnect those loads. The guys at the tire shop were very impressed by this stealthy security device. Anyone wnat one I can tell them where to buy it and draw up a system diagram to show you how to wire it up. The device is sealed and good for under hood use (semi-truck, 300K miles) I'll even tell you the secret so you can raise the voltage setpoint. They sell them only at 12.0V and 12.3V. No harm comes to a battery if it cycles down to 12.5V, 12.3V just a little bit. Link to comment Share on other sites More sharing options...
rallyruss Posted March 17, 2004 Share Posted March 17, 2004 that cut out sounds like a sweet set up. scooby I hate to tell you but I would be past your toggle switch so fast no mater where you put it. all someone would have to do is jumper right at the starter and down the road you go. to answer your other question. yes you have an electric fuel pump its in the right rear of the car. the wireing is under the carpet on the pass side then up under dash. switches are not meant to carry a large load unless they are a Heavy duty unit. thats why you use a relay. they do the real work carring the amps. Link to comment Share on other sites More sharing options...
nutt7 Posted March 17, 2004 Share Posted March 17, 2004 Shean, tell radio shack you need a 30 amp relay for your car and they should have one...its like a 1.5'' cube with a tab sticking out the top and 5 metal prongs out the bottom...I can post a pic if you want... also, I ran a magnetic switch in the ashtray behind the center console in my civic and with the ashtray open, it would not start because the magnet was too far from the switch...close the tray and the magnet sits right over the switch, activating the relay, which in turn connected the starter wires. another magnet switch idea would be to adhere the switch inside a plastic panel somewhere and touch a magnet over it while starting the car...you can put the magnet on a key chain or hide it in the car or something... i like this kinda stuff so let me know if you need help -eric Link to comment Share on other sites More sharing options...
nutt7 Posted March 17, 2004 Share Posted March 17, 2004 hence the avatar...GLAVEN!! Link to comment Share on other sites More sharing options...
The Scooby Posted March 17, 2004 Author Share Posted March 17, 2004 mr. radon: please send me a diagram on how to do that, i would love to know how to do that. rallyruss: well maybe this one switch, but when im done, you wont want to try to open my door. im gettin a car alarm, it has 2 aluxary channels, one is being hooked to my windows to roll them down when i hit the pad on the key chain, the otehr arms my security system, car battery hooked to all the door handles, so all you will remember is that you touched the door handle, and you woke up on the ground. Thanks for your guys help!! Shean Link to comment Share on other sites More sharing options...
rallyruss Posted March 17, 2004 Share Posted March 17, 2004 hmm that good you have more in mind than just that. 12V ? knock you out? 12v wont do squat. you need high voltage and lots of it. then you need to isolate the handle from the rest of the car. well Ill stop now Im sure you have a plan. can someone do a write up on wiring in relays to put in the USMB. It seems this is a mystry area. I know we have covered it a few times but it keeps coming up. Link to comment Share on other sites More sharing options...
The Scooby Posted March 17, 2004 Author Share Posted March 17, 2004 im going to run a thick wire so that it wont bend up under the handle so it moved with the handle, but it will be hooked to the battery so its not really the handle, but rather a wire that will shock the crap out fo the person. Link to comment Share on other sites More sharing options...
baccaruda Posted March 17, 2004 Share Posted March 17, 2004 i plan to put a mystery "car won't start" switch in my cars too.. in my wagon, i'm putting it in one of the 4 gray panels that sit next to the rear defrost and cruise control switches. I grabbed that switch assembly from a car that had the pneumatic height adjust switch there.. took out the HA switch from the assembly. all i have to do is put it in my assembly with a blank gray cover over it and it won't look like anything at all. I want to put other switches in those spots too, give it a nice clean look. Link to comment Share on other sites More sharing options...
scubaroo Posted March 17, 2004 Share Posted March 17, 2004 :wave: try using the cigar lighter:brow: Link to comment Share on other sites More sharing options...
The Scooby Posted March 17, 2004 Author Share Posted March 17, 2004 ya im just gonna run a relay and a switch on the coil power wire, also a fuel pump kill. also im thinking of gettin an extra wiper squirter motor and tank to spray gas into the exhaust, along with running a spark plug in the exhaust and a coil to make those pesky tailgaters back off. :madder: Shean Link to comment Share on other sites More sharing options...
rallyruss Posted March 17, 2004 Share Posted March 17, 2004 scooby go out to your car and touch both batt posts at the same time. did you get shocked? hmm work on that fuel pump kill switch idea that would be a good one. and if you use a relay you would actualy improve the system. Link to comment Share on other sites More sharing options...
The Scooby Posted March 17, 2004 Author Share Posted March 17, 2004 what do you mean make it better, fuel kill settup? is it a strait wire to the ECM in the car with no relay?? or what? Link to comment Share on other sites More sharing options...
rallyruss Posted March 17, 2004 Share Posted March 17, 2004 thats how my old 85 gl was set up. I belive 86 is the same. they just used a transistor in the pcm. I recomend checking a diagram but I 90% sure yous is the same and yeah you use the relay to kill the fuel pump and power it up. Link to comment Share on other sites More sharing options...
The Scooby Posted March 17, 2004 Author Share Posted March 17, 2004 alrighty, thanks now i just have to wire up a fuel solnoid, make a custom gas tank, and put in the spark plug, coil, and wire it all up. then see how far i can shoot flames. Link to comment Share on other sites More sharing options...
