mcbrat Posted December 8, 2011 Share Posted December 8, 2011 1994 SS stock EJ22T. don't notice it if RPMs are up... but just off idle whether stopped or moving, the noise frequency increases with RPMs, but is not a consistent noise. seems to waver... 170k on stock engine and turbo (assuming it's original) clutch has been starting to slip occasionally. I'm hoping it's the turbo or the clutch, because both are going to be replaced shortly... TD04 (75k) sitting on the shelf waiting... any thoughts... Link to comment Share on other sites More sharing options...
bheinen74 Posted December 8, 2011 Share Posted December 8, 2011 could be front pulley separating. My 94 wagon has that going on now too, fairly typical after being that old. Link to comment Share on other sites More sharing options...
The Dude Abides Posted December 8, 2011 Share Posted December 8, 2011 Not a subaru, but my van was doing the same thing. When i replaced the pully and the tensioner the noise went away. I replaced the belt at the same time as well. Link to comment Share on other sites More sharing options...
bheinen74 Posted December 8, 2011 Share Posted December 8, 2011 or check AC compressor for vibration, the bearings in them go about this miles too....if so, cut the belt off. hope it is something easy. Link to comment Share on other sites More sharing options...
idosubaru Posted December 8, 2011 Share Posted December 8, 2011 tap, screech, knock, squeal? if you're saying "bad" it doesn't sound good, boo!? sounds like you're not leaning towards these but accessory belts/pulleys? removing both belts and cranking the motor rules out belts, pulleys, alt, p/s, a/c bearings. Link to comment Share on other sites More sharing options...
mcbrat Posted December 8, 2011 Author Share Posted December 8, 2011 when I first heard it, it reminded me of a fan motor going bad. labored. kind of a lower pitched, sputtery growl.... if that makes sense.... bad enough that I didn't feel like driving it for my work commute... Link to comment Share on other sites More sharing options...
ShawnW Posted December 8, 2011 Share Posted December 8, 2011 My folks have the big parts delivery and theres 2 hoses coming priority mail. Hope its the turbocharger or a timing belt idler which would be my two guesses. Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 8, 2011 Share Posted December 8, 2011 Timing belt slapping the cover. Sounds kinda like this? Link to comment Share on other sites More sharing options...
mcbrat Posted December 9, 2011 Author Share Posted December 9, 2011 No. Doesn't soind like that. It is accompanied by a vibration too that a can vaguely feel thru the shifter. Link to comment Share on other sites More sharing options...
ShawnW Posted December 9, 2011 Share Posted December 9, 2011 Driveshaft u joint or carrier bearing possibly. Link to comment Share on other sites More sharing options...
bheinen74 Posted December 9, 2011 Share Posted December 9, 2011 alternator bearing? Link to comment Share on other sites More sharing options...
mcbrat Posted December 10, 2011 Author Share Posted December 10, 2011 ShawnW said: Driveshaft u joint or carrier bearing possibly. nope. does it while parked... but I'll verify... I got all my parts today for the clutch and axle swap... still need to get the items needed for the turbo swap though... Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 10, 2011 Share Posted December 10, 2011 Could be the release bearing rattling around. Link to comment Share on other sites More sharing options...
mcbrat Posted December 12, 2011 Author Share Posted December 12, 2011 it's definitely in the front of the engine... haven't had a chance to see what exactly it is though... Link to comment Share on other sites More sharing options...
bheinen74 Posted December 12, 2011 Share Posted December 12, 2011 waterpump maybe if not the alternator. Link to comment Share on other sites More sharing options...
mcbrat Posted December 29, 2011 Author Share Posted December 29, 2011 AC Belt tensioner.... it was so toasty, you could hold it by the pulley with the bracket hanging down, and turn it, and the bracket would move with it, and hold at a 90 degree angle without any rotation! Link to comment Share on other sites More sharing options...
