Ratty2Austin Posted March 16, 2004 Share Posted March 16, 2004 well, after my test run yesterday, doing some urban offroading.... the tranny decided it did not agree with my linkage anymore.... I pushed the lever down to remove it from 4wd Lo, and it went all the way down to the console, but it did not disengage 4wd, so I tried the back up and also the gravel trick,and then later, even the jack up the back of the car and release the tension trick, but the lever is now jammed against the console, and to make it worse, i looked under the car, and it seems to have broken somewhere at the point at which it goes into the car, it is now leaking gear oil from the 4wd selector lever where it goes into the tranny.... oh well i guess... the tranny never shifted well ever sence I got it, so its time for a new one! in the mean time, i need to go remove a rear axle so that I can drive on pavement till i can get it fixed anyone have a known GOOD 5spd d/r 3.9 laying around I could barter for???? please??? (i have some pugs, or other parts too) Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 16, 2004 Share Posted March 16, 2004 What are you doing with the old tranny? Want to donate it to GD's tranny rebuild shop? GD Link to comment Share on other sites More sharing options...
Skipper47 Posted March 16, 2004 Share Posted March 16, 2004 How much would a decent 5spd cost from a junkyard.? Just curious... Link to comment Share on other sites More sharing options...
Bratwerst Posted March 16, 2004 Share Posted March 16, 2004 I actually wanted it for myself - but you're in more dire need of it... Austin, talk to mark - he has one FS, you can have my spot in line if you like... - Erik Hosa - Tacoma, WA - Link to comment Share on other sites More sharing options...
s'ko Posted March 16, 2004 Share Posted March 16, 2004 I saw a 5spd D/R in the local pick a part from an 88 wagon. Not sure if the engine or the tranny was the reason it was in the the bone yard. I will try to see how much it costs. BW Link to comment Share on other sites More sharing options...
